Go to Post Getting your questions answered is what the big thick manual is for....GO READ. - Dorienne [more]
Unread 12-01-2014, 22:50
wre136's Avatar
wre136 wre136 is offline
AKA: Will Edds
FRC #2461 (The METAL-SKINS)
wre136 is an unknown quantity at this point
Question Adding More than 4 Joysticks to an FRC LabVIEW Program
I am building a program for my FRC team and I have need to have up to six controllers. However, the Open Joystick VI only allows up to 4 USB inputs. Is there a way to increase this number or is it is a limitation of the driver station?
Unread 12-01-2014, 23:14
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Re: Adding More than 4 Joysticks to an FRC LabVIEW Program
The driver station software shows 6 inputs in the input list....I don't know much about labview (besides making a simple tank drive), but maybe you could try giving the vi an int?
Unread 12-01-2014, 23:16
Your two drivers can hold three controllers each
We are limited to 4 USB ports plus one Cypress set of inputs.
If you can figure out a way to multiplex some of the controllers to look like a single USB input then you might have a chance.
The Cypress with some wiring can be made to pass through joystick/button type information.
Unread 12-01-2014, 23:17
The driver station only sends 4 joysticks to the robot. See http://wpilib.screenstepslive.com/s/...ation-software
New for 2014 - This box now shows up to 6 joysticks to allow use of the full 4 devices when only using 1 part of a compound device such as the TI Launchpad. Only the first 4 devices are transmitted to the robot!!!
Unread 13-01-2014, 09:26
The 4-joystick limit is solid, but that applies only to joystick data sent by the Driver Station program. If you write your own Dashboard, you can have it read anything you want and send the data using your choice of protocol, then receive that data in your own program on the robot, without worrying about the Driver Station limitations.
Unread 13-01-2014, 10:35
Racer26 Racer26 is offline
What application could you possibly need 6 joysticks for to control one robot?
Unread 14-01-2014, 18:30
wre136's Avatar
AKA: Will Edds
It's a game scoring application. Rather than writing down our scoring on paper for a match, students can just hit a bottom to say a team scored high goal, hit another to say a team scored low goal. That way results are automatically put into excel form.
Since there are 6 teams on the field, that is way I would like 6 controllers.
Unread 14-01-2014, 20:11
Why are you using a robot controller and driver station to do it though? Just build a native LabVIEW app that runs on windows and talks directly to the controllers...
Unread 14-01-2014, 21:20
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Or, you know, have six sets of push buttons on a cypress board...
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 14-01-2014, 22:10
Are you trying to read joysticks that are directly connected to the computer running the LabVIEW program? You can't use the Joystick Open vi for that; it's only for use with a robot program being controlled by a Driver Station.
Look at the Input Device Control functions in the Connectivity subpalette.
Unread 16-01-2014, 21:41
wre136's Avatar
AKA: Will Edds
Thumbs up Re: Adding More than 4 Joysticks to an FRC LabVIEW Program
Thank you for your help and direction on this. I wasn't sure how to grab joystick input directly in LabVIEW. The connectivity pallet did have everything I needed as stated and once initialized, worked much the same as the joystick VI for FRC.
Name:	Joystick Example.PNG
Unread 17-01-2014, 08:04
Jmulderig Jmulderig is offline
FRC #3460
Jmulderig is an unknown quantity at this point
search for "Falcon robotics scouting" and talk to them...They developed a similar program last year although it wasnt in labview. they may have some insight
