Go to Post You must wear safety glasses at all times, so please bring them. - Don Wright [more]
Unread 13-01-2014, 11:49
Mr.circlemonger Mr.circlemonger is offline
FRC #4110
Mr.circlemonger is an unknown quantity at this point
Opinions: Magnum 775 Legal?
Since the magnum 775 is based on the legal RS775, it appears it would be legal for competition use. Can anyone confirm/deny this? Link for specs
http://www.robotmarketplace.com/prod...MAGNUM775.html
Unread 13-01-2014, 11:54
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Opinions: Magnum 775 Legal?
Generally speaking FIRST is very specific about requiring specific models for motors and disallowing anything else (meaning that motor is probably not legal).
Of course, I'm not the GDC, so the best place to ask that questions might be the Q&A.
Unread 13-01-2014, 11:55
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Look at the datasheet attached to that product, http://www.robotmarketplace.com/prod..._DataSheet.pdf
This appears to be from Leshi Motors, part number LS775-PX. That part number does not meet R29, which specifies (for the RS775) the following part numbers:
M7-RS775-18 / RS775PH-6221
M7-RS775-12 / RS775WC-8514
There's nothing wrong with using the rest of the assembly, but you may need to swap the motor if the part number is different.
2016: Lake Superior WFFA
Unread 13-01-2014, 11:58
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
Not only is the motor not legal, it's much more than the corresponding motor and near-equivalent gearbox from banebots.
And the magnum is out of stock, as well.
Team 501 Academic Advisor, Systems Build Mentor
Unread 13-01-2014, 12:30
FRC #4110
Thanks for the advice. We have four of these units and they look like the ones use on BOOM DONE but we won't plan to use them.
Unread 13-01-2014, 12:33
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Just switch out the motor with a legal RS775 motor and you will be fine.
Unread 13-01-2014, 13:27
Chris is me's Avatar
AKA: Pinecone
FIRST is very specific about the actual motors used, but COTS gearboxes or other assemblies are generally fine. If there is a COTS gearbox that uses 775-style motor mounting, just switch the provided motor for a Banebots motor and you're totally legal.
