| Thread Tools |
Rating:
Display Modes |
#16
Re: Forwards and Backwards Ball Pickup
Lots of discussion about moving intakes around to pick up from multiple sides...what about two intakes? It seems like it might be hard to package everything.
#17
The design we have planned takes up as much space as a single sided intake, but has a few extra pieces, of course. It shouldn't be hard to package at all. I don't know about how other teams are trying this, if they are, and if their design is difficult to make fit especially if their intakes are separate.
#20
#22
Having two intakes could also come in handy if you are trying to catch the ball. We are working on something along these lines. How well it works out is yet to be seen.
I appluad/enjoy it when teams do out of the box things that may or may not be of great benifit. As long as you are learning and having fun then that is all that matters. IMO |
#23
I'm not trying to say that teams who may exclude difficult or unproven designs are not always learning as much as teams who go a different route, but the teams who dare to do something different will probably learn something that the cautious teams will not. Last edited by bEdhEd : 13-01-2014 at 13:48. |
#24
Having a way to pick up from both sides does have its advantages. I see what you are going for now. You are going to want a good balance between torque and speed in my opinion. Or you can keep your loader light enough so that you can have a reasonable amount of speed. I don't think it would be a good idea to have a way to pick up from both sides but have it take a while for it to get to each side. That's why I said why no just turn.
#25
I'm gonna go ahead and post the unpopular opinion: why have a two sided pickup? There's only ever going to be one ball on the field, so long as you just keep track of it it really isn't necessary. Even if you're worried about the rebound, just have the robot turn 180 degrees be part of the shoot sequence. It's just gonna add more complication and an ounce more flair to teams when they try to appeal to scouters.
All in all, personally not worth it. |
#26
Just an idea: build an intake on one side, and spend the same time you would have taken to build a double sided intake, practicing.
Again just pure opinion, but I think we will see good robots with lots of practice beat amazing robots with little practice. |
#28
And if we don't build a second robot, well, let's just do everything to make sure two get built. ![]() Last edited by bEdhEd : 14-01-2014 at 07:22. |
#29
http://www.chiefdelphi.com/media/img...16ffd890_l.jpg The diameter is about a foot, so it's like being able to drive the arm with a 12" sprocket , and only using 2 FP motors. We intend on using this type of system again this year for a full rotation. Our heavy arm last year took about a second to get from down to top position, and we plan on having the same success with it this year. Turning around and rotating the arm should both take about the same amount of time. The big advantage I forgot to mention is that during autonomous mode, we will be able to grab balls from behind us without turning, in the likely event that a robot has an unreliable, ineffective, or no autonomous mode. Just have the ball touch the other robot, and have the ball right behind our robot, and have programs for one two, or all three ball autonomous modes. If an alliance member is a goalie, they can place the ball behind us when it's in between the truss and the zone line, and we will never have to remove a ball from the beginning of the match. My team would not prefer to turn around during auto, but rather go forwards and back, and reduce the chance of bumping into an alliance partner during auto if anything goes wrong during this period of the match. Last edited by bEdhEd : 14-01-2014 at 07:48. |
