Go to Post Courtesy is the key. - Tom Schindler [more]
Unread 13-01-2014, 14:46
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Releasing winch system without shifters
Maybe this could spark some ideas?
http://www.daytonsuperiorproducts.co...-sprocket.html
Unread 13-01-2014, 14:47
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Originally Posted by Jon Stratis View Post
I'm intrigued by this idea... I hope I see it somewhere to know if it works!
I think it's a pretty good idea, I don't think anyone has thought of this.
Just make sure that the windup only takes less than a revolution of that gear.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 13-01-2014, 14:54
Aren_Hill's Avatar
Build Nifty Things
Ether linked out the point in Build Blitz where we explain it.
http://www.chiefdelphi.com/forums/sh...68&postcount=5
A guy who likes robots.
Unread 13-01-2014, 14:56
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I was talking about the concept of removing part of a gear to create a "slip point" for releasing the catapult, not the over-center linkage from the BuildBlitz... I've seen linkages like that before
2016: Lake Superior WFFA
Unread 13-01-2014, 15:04
magnets's Avatar
magnets magnets is offline
One nice feature of a cam is that, with a little math, you can derive the equation for the spiral so that the torque required to drive it remains constant as it is pulling back the arm. Then you can use that equation to cut out the cam.
Or, you could derive the equation so you gained mechanical advantage (and torque) as you wound back. It takes more force to stretch the surgical tubing at the end than it does at the beginning.
For another type of release mechanism, use a doorknob or gate latch.
Unread 13-01-2014, 15:20
What you want is for the torque required to drive the spiral cam to remain constant (think about it):
True for many (most) designs but not necessarily true for all. It depends on how the mechanical advantage of the linkage changes as the kicker is being pulled back. In any event, what you want is for the torque required to drive the spiral cam to remain constant. To achieve that you would need to take into account the F=k*x spring constant of the tubing as well as any linkage geometry changes
Unread 13-01-2014, 15:27
Originally Posted by androb4 View Post
That's sweet!
I've made this (https://www.dropbox.com/s/vmkm7jq1km...%2012%20AM.png) the other day using Inventor's Create Spiral tool. What do you think?
I can't tell for sure but it doesn't look quite right. Can you post the generating equation?
Unread 13-01-2014, 16:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That depends on your wording and if the surgical tubing (or other spring mechanism) is strained beyond the linear elastic region. While, yes, it will take more total force to stretch the material from 0 to Y than 0 to X (assuming Y>X), the force to stretch from X to X+1 may not be more than the force required to stretch from X-1 to X.
Point 1 on that diagram represents the yield stress, where the linear elastic region stops and any further strain on the object will result in some permanent deformation.
Ideally, teams would keep their surgical turbing (or other spring) entirely within the linear elastic region so the characteristics of their launch remain consistent over time. However, the reality of the situation is often that, in order to achieve enough initial force given a limited travel distance, the tubing is stretched beyond the yield stress, and some permanent deformation occurs to the tubing each time it is stretched.
Unread 13-01-2014, 16:40
pfreivald's Avatar
pfreivald pfreivald is online now
AKA: Patrick Freivald
We considered it--a rack an pinion with missing teeth on the pinion.
We were afraid that the pinion teeth near the broken teeth would end up breaking during competition.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 13-01-2014, 17:04
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by Yerdan View Post
Hi guys,are there any ways of releasing winch system without using shifters(any optional systems)?
How about scissors to cut the spring/rope?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 13-01-2014, 17:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'd say it's pretty likely that they want to do this more than once a match...
2001-2004: Team 100
2006-Present: Team 254
Unread 13-01-2014, 17:10
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
An option we are considering is to use a bicycle disc brake like we used to 2011. We used brake cable actuated by a two inch stroke one inch bore pneumatic. The same set up is able to hold our prototype catapult. If it loses pressure, it will release its grip, so you have to be careful. Although a gradual loss of pressure tends to make it slip slowly.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
