Go to Post Inspect every connection after every match. Use your eyes, ears and nose. - Al Skierkiewicz [more]
Unread 13-01-2014, 18:28
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Serial Sonic Sensor
We are trying to set up a sonic sensor for our robot and cannot get it to display values to the dashboard. We would appreciate any help, but first take note: our sensor does not work with the ultrasonic sensor .vi's. It has to use the serial .vi's.
Thank you.
Unread 13-01-2014, 18:35
Re: Serial Sonic Sensor
It sounds like there are two things you're trying to do. 1) Read data from the sensor. 2) Output that data to the dashboard. Which are you having trouble with?
If it's the former, a link to the datasheet of your sensor would be required.
Unread 13-01-2014, 18:37
AKA: Ethan
How would I go about doing that?
Unread 14-01-2014, 22:25
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Most ultrasonic sensors you buy will be analogue. This means it will output a voltage between two values (such as 0 to 5v) which can be linearily equated to a range by scaling it appropriately. If your sensor is from Maxbotix, everything you need is here, and if it isn't, the same concepts typically apply.
[in the event that serial sonic sensors and analogue sonar rangefinders aren't the same thing, my apologies]
Unread 15-01-2014, 10:28
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
You need to let us know what the part number for your sensor is. There are a lot of different options out there in the world.
For example you might have one of these (they work differently):
Also, some more information on what you problem is would be helpful. Are you getting error messages? What is making you think things aren't working?
Providing your code would also be a good start.
http://team2168.org
