Go to Post Don't you just wish life had a redo button? - DHarris [more]
Unread 13-01-2014, 17:18
chiefwebmaster's Avatar
chiefwebmaster chiefwebmaster is offline
FRC #3169
chiefwebmaster is an unknown quantity at this point
Default Mecanum Code Not Working
Hello,
We are having trouble getting the default mecanum drive code up and running. Currently when the code is deployed the robot goes full speed forward even when the joystick is in the center position. When we move the joystick the robot moves full power in that direction.
We also tried the mecanum with arm in the simulator and the robot just spins in a clockwise circle without any input from the joystick.
Is anyone else having this problem?
Thanks for your help,
Garrett
Unread 13-01-2014, 17:26
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Re: Default Mecanum Code Not Working
Make sure you have calibrated your speed controllers correctly. Additionally, make sure your joysticks are working correctly with your computer (Control Panel > Devices And Printers > right click controller > game controller settings > properties). Also, check to see that you are sending the right axis to the right input of the VI (Axis 1 and 2 on an attack 3 joystick are X and Y respectively, Axis 3 is the throttle knob).
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 13-01-2014, 21:23
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
You can use the Joy Stick Explorer to verify joystick axis and values:
http://firstforge.wpi.edu/sf/frs/do/...stick_explorer
Brian K
Team 1225 Robotics Mentor
Unread 13-01-2014, 22:27
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
Maybe your joysticks are faulty. Try running the program from the main block diagram, and go in to your teleop code and put a probe on the joystick outputs.
Unread 13-01-2014, 22:38
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
if all else fails, reimage the Crio and start a new project... sometimes a fresh start is the easiest way to fix a problem.
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 14-01-2014, 15:25
FRC #3169
Thanks,
Apparently the throttle has to be centered and not all the way down.
Garrett
