Go to Post We all need to remember to be careful at these competitions. Danger lies in the most unexpected (and comical) places. - Alexander McGee [more]
Unread 13-01-2014, 20:06
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
Troubles with downloading code over wifi
So I am having a strange problem when trying to download code over wifi to the crio using Java and Netbeans 7.4.
When I start downloading code, it tells me my netmask is 255.255.255.254, which I made sure numerous times that it is not. However, it downloads the code about 3 to 4 times in a row with succession. Then on the 4th or 5th try it stops at the "netmask" output and I am forced to restart the robot since I can no longer connect to it.
Downloading code over Ethernet works fine and so does connecting to the robot via wifi to drive (without downloading code). I have disabled my firewalls.
Team 842 Falcon Robotics: 2011-2015 (President, Head Programmer, Drive Team)
Arizona Regional Winners: 2012-2014 (Thanks 610, 1212, 1726, 3944, 2486, 2403)
Curie Division Semi-Finalists: 2014 (Thanks 1311, 2013, 2928)
Las Vegas Semi-Finalists: 2015 (Thanks 3495, 4415)
Curie Division Quarter-Finalists: 2015 (Thanks 107, 228, 649)
2015 - 2016: Programming, Drive Team, and Strategy Mentor for Team 3187, The Titans
Studying Computer Science- Software Engineering at ASU (Class of 2019)
Unread 13-01-2014, 22:50
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Re: Troubles with downloading code over wifi
We have three identical laptops and have this same problem on one of them. Exactly as you say. Downloads code fine when wired. Gives us this goofy net mask when we are wireless. Would love to know a solution. Will post if we find one.
Unread 14-01-2014, 11:42
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Is your router configured properly? Also do you have the proper static IP configured on the computer?
Unread 14-01-2014, 13:58
College Student
I have reconfigured my router numerous times and I can connect to it fine for just driving and downloading code a couple of times. The static ip is also correct.
