Go to Post Build season can't come soon enough. - Ryan Dognaux [more]
Unread 13-01-2014, 21:17
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
cRIO FRC Imaging Tool Error
Hello! Has anybody has problems with the imaging tool? Since I joined my actual team last year, we hadn't been able to flash the cRIO with the tool, and instead had to access the ftp server on ftp://10.x.y.2 and place the image manually. A few days ago I tried changing the name to CDCH2576, and it magically worked! But this error repeated itself today, when I was skyping with team 4960 Polibot (San Carlos, Chile). I was trying to flash with the name "POLIBOT4960", but the cRIO was once again unreachable. So when the other team programmer arrived, he reminded me of what I had done with the name, and not surprisingly, the name "POLI4960" worked! So any idea of what's going on? We had a theory of the cRIO working with the old DOS 8-character naming system, but I highly doubt it
Unread 13-01-2014, 21:56
1024Programming 1024Programming is offline
FRC #1024
1024Programming is an unknown quantity at this point
We may be seeing the same thing. Once the CRio became unreachable, how did you get it to communicate again? Thanks
Unread 13-01-2014, 22:41
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Re: cRIO FRC Imaging Tool Error
What IP address was your laptop using when you tried to image it?
Where you going through a router, over WIFI, through the bridge, or directly to the Crio?
Can you ping the Crio when it fails to show up in the imaging tool?
It would help a little bit if you could give a little more detail about your setup.
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 13-01-2014, 23:04
AKA: Lucas Alvarez
randalcr:
The IP displayed by the cRIO was originally 10.11.11.2.
I selected 10.49.60.5 and 255.0.0.0 as gateway.
They had a crossed ethernet cable directly from the cRIO to the PC.
And the cRIO never failed to show up in the imaging tool, it just threw an unreachable error after trying to connect.
Eventually the cRIO had 10.49.60.2 as the IP, which was the original one I tried to assign it. We then managed to flash it with that name ("POLI4960"), but not with the longer one ("POLIBOT4960")
Unread 13-01-2014, 23:08
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
use 10.49.60.6 as your computer's IP address and 255.255.255.0 as the subnet, dont put a gateway unless you're going through a router or the bridge.
Unread 13-01-2014, 23:27
AKA: Lucas Alvarez
Thanks!
any specific reason for using number 6? cause we always used 5.
and concerning the gateway, I thought it was best to use 255.0.0.0 because I was going to change the IP....mind explaining why it isn't necessary?
Unread 13-01-2014, 23:41
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
When First started using the 8 slot crios the manual and all the NI reps said to use 10.XX.YY.6 when imaging the crio, since then whenever I have had a problem with one, I use .6 and the problem vanishes 99.99% of the time.
As for the subnet, I have seen a few cases where setting the subnet to 255.255.255.0 makes a difference. It really shouldn't matter, but you can't argue with the results in most cases.
Hope this helps!
Unread 13-01-2014, 23:56
AKA: Lucas Alvarez
Hahaha, you're right about the results. Well thanks for everything!
Unread 14-01-2014, 09:09
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
No problem, glad I could help you out!
