Go to Post Wow, that is awfully impressive! How can a guy in the WWF be so smart? Oh, it's LIKE the WWF...:p - DonRotolo [more]
Unread 14-01-2014, 01:33
azcalg's Avatar
azcalg azcalg is offline
FRC #1212 (Sentinels)
azcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the rough
Re: 1212 pneumatic catapult prototype
Originally Posted by Dave Otis View Post
Any advice based on your successful launch?
I didn't do the pneumatics on the prototype, I just built it with some others, so I don't know a whole lot about pneumatics but from what you said, you may need to either use more pistons or a bigger piston. Your setup actually sounds pretty similar to our initial attempt, after which we got it shooting better with a larger piston, after which we got it shooting better with multiple smaller pistons. Sorry I can't help you much on the pneumatic side of things. On the mechanical side, however, I can help a bit more. If you need more speed, you can either attach the piston closer to the pivot point or make the catapult longer. If you move the piston half the distance closer, you will get twice the speed but it will require twice the force. Another idea is to make the angle between the catapult and piston smaller. As Jeffy said, it seems that the pressure builds before it shoots like this. I made a picture for you
Unread 14-01-2014, 12:05
Hoffer5236's Avatar
Hoffer5236 Hoffer5236 is offline
Project Manager
AKA: Matthew Hoffer
FRC #5236 (Man O' War)
Hoffer5236 is on a distinguished road
Originally Posted by falconmaster View Post
How did you get the varying pressure for the pistons to make them shoot different heights? We cannot figure out how to do that.
Unread 14-01-2014, 12:24
I wonder if you could treat the solenoid like a MOSFET and PWM it. Has anyone ever tried that?
Unread 14-01-2014, 16:52
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
This is how the turbo boost control works on my Subaru. Or at least how it used to work before I built my own boost controller.
A quick test should show if the valve can respond quickly enough - listen for the chatter and find the frequency it stops chattering.
Another idea for catapult distance adjustment would be to open the valve for a varying time. A slower valve that cannot be pwm'd may still be fast enough for one opening and one closing within the filling time.
Graham.
Graham
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
