Go to Post My advice is anytime your intuition tells you something, double check it with physics. - tennispro9911 [more]
Go Back   Chief Delphi > Competition > FRC Game Design
Unread 05-01-2014, 22:23
defied defied is offline
FRC #2557
defied is an unknown quantity at this point
Field Management White Paper?
Do we know when they intend to post this?
Thanks,
D
Unread 05-01-2014, 22:33
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Field Management White Paper?
http://www.usfirst.org/sites/default...Paper_RevA.pdf
A simple google search provided this, and although it is from last year, the likelihood of significant changes this year is incredibly slim to nonexistentexistant.
Unread 05-01-2014, 22:38
FRC #2557
I should have been more clear. I am wondering if / when they will post the 2014 whitepaper.
Thanks,
D
Unread 10-01-2014, 19:21
That is the version referenced in the 2014 manual, in R58. I think that means there won't be an update.
Unread 11-01-2014, 11:22
gmendezweeks gmendezweeks is offline
FRC #4645
gmendezweeks is an unknown quantity at this point
Hey, I'm from a second year FRC team and we really need to verify if the white paper that is referenced in the 2014 manual and kickoff video is going to be the same document that was used last year.
Unread 13-01-2014, 14:50
FRC #2557
So, am I to take that the email they had sent out earlier this year acknowledging that there were flaws in the FMS and the scoring system that would be resolved are, in fact, not going to be resolved?
Thanks,
D
Unread 13-01-2014, 15:42
If you would like an official response, you should ask in the Q/A.
I think you might be referring to the manual frisbee counting errors, but it would help for you to provide more details. See http://www.chiefdelphi.com/forums/sh...d.php?t=116895. I think part of the correction is through game design, reducing the number of active game pieces from over 100 to at most 6, and usually 2, which greatly reduces the opportunity for error.
Unread 13-01-2014, 16:08
FRC #2557
So, instead of sixty some odd frisbees in 5 targets, you have 6 balls, 6 robots, that are all responsible for passing, throwing, catching, possessing, a big ball and scoring in one of 4 goals each team?
Is that one score-taker per robot? Can't see that going wrong. 0]
Does the reduction of objects really make it less flawed? My vote is no.
Thanks,
D
Unread 14-01-2014, 08:15
One per ball seems sufficient. The detailed record-keeping of ball possessions doesn't start until after all the autonomous balls have been scored, and it's pretty straightforward.
Unread 14-01-2014, 10:20
FRC #2557
I guess we'll see.
D
