Go to Post Every team in FIRST can make this choice. Be positive, help others, and work like a maniac behind the scenes. This approach will bring you joy and satisfaction, whether you win or not. - OZ_341 [more]
Unread 14-01-2014, 09:32
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
Re: Ri3d Gearbox
Dan,
What's the difference between the Modulox Shifter Shaft and the Long SS Hex Shaft that AndyMark currently sells?
Just from looking at the CAD of the gearbox the two looked more or less interchangeable.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Unread 14-01-2014, 21:31
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Ri3d Gearbox
Originally Posted by Jacob Paikoff View Post
Dan,
I may need to do a deeper dive but I believe the major difference is that the the Long SS Hex Shaft is missing the bore and slot to shift the dog. I believe in the AM shifters these features are incorporated in a cluster shaft.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 16-01-2014, 23:43
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Re: Ri3d Gearbox
We are currently designing a winch system to draw back and release our catapult and I am intrigued by the lunchbox. A few questions about your Ri3D robot...how many pounds of force did it take to draw the catapult back? We need about 50-75 lbs or force at about 22 inches from the catapult's pivot point and I am curious as to how well this transmission will perform. We started designing for a WCP 2 speed transmission but later determined that it was not the best one to use.
Thanks, Keegan
Unread 18-01-2014, 09:54
iR3 Creative
AKA: Dan Richardson
Re: Ri3d Gearbox
I apologize, I was incorrect. The only difference that I can tell is that the hex portion, and the 3/8" round version of ours are slightly longer. If it were just the hex it would be interchangeable but the 3/8" in the Long SS Hex Shaft round would fall short of the bearing.
Unread 18-01-2014, 16:51
FRC reunion tour
FRC #0079 (Krunch)
Re: Ri3d Gearbox
Thanks Dan, I'm glad you cleared that up.
Unread 22-01-2014, 23:40
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Ri3d Gearbox
Is there an updated BOM for with the other link that was "tbd"?
Unread 23-01-2014, 08:21
iR3 Creative
AKA: Dan Richardson
Re: Ri3d Gearbox
Looks like its the site has the shaft as part number AM-2777 and they have a kit listed under AM-2774.
It doesn't look like there is an order page for the shaft. If you're trying to place an order maybe you can call and have them add the shaft to it.
Unread 16-02-2014, 22:39
arun4444 arun4444 is offline
FRC #3760
arun4444 has a little shameless behaviour in the past
Re: Ri3d Gearbox
Here is the shaft
http://www.andymark.com/product-p/am-2770.htm
Unread 16-02-2014, 23:57
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
Re: Ri3d Gearbox
Thank you, but it's a little late now
