Go to Post At a much more pragmatic level, organization is what seperates a team full people with really cool unrealized dreams and a team that is trying to figure out it's alliance picks. - phrontist [more]
Unread 09-01-2014, 18:37
Fifthparallel Fifthparallel is offline
AKA: Sam Chen
FRC #1410
Fifthparallel is an unknown quantity at this point
Windows 8 -- Reinstall failure
There was an issue wherein somebody installing WRWB (the first time) on a windows 8 laptop accidentally ran WB 3.0.1 first, so we tried to uninstall it.
It did not uninstall properly (we used the un/installer provided in the mtool folder inside the maintenance folder of C:\WindRiver). Now, when we try to re-install WorkBench 3.0, it fails at start with a "an exception occurred during installation" dialog, and recommends a place to look. Unfortunately, the location the log is supposed to be saved at does not exist (nor can we find its analogue) because it references the "C:\Documents and Settings\" location only provided in Windows XP.
To recap:
1) Workbench 3.0.1 uninstall failure
2) Workbench 3.0.1 installation fails
3) Cannot find log which failed installation says contains error messages because of outdated naming convention.
What can we do to solve this problem? It is causing a considerable amount of agony.
sudo chmod u+x helloworld.sh
gotta start somewhere.
Unread 10-01-2014, 10:16
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: Windows 8 -- Reinstall failure
The log is likely relative to the Users folder (Docs and Settings in XP, User); if it isn't then try creating a Documents and Settings folder to give it a place to write to.
However, you absolutely need to install 3.0.1 first no matter what OS, then you use the second disc to patch to 3.3.1 for Non-XP32 bit systems.
But, to answer your direct question. I would first try removing the C:\Windriver directory completely. I think this is all you need to do, I don't think anything in the registry would cause you trouble for reinstalling.
Also, there is an issue with installing WindRiver on windows 8! See the instructions for the work-around http://wpilib.screenstepslive.com/s/...elopment-tools
Unread 10-01-2014, 11:59
AKA: Sam Chen
FRC #1410
We've already tried blowing away the WindRiver folder several times now.
Eventually, we just copied the WindRiver folder from a working machine, dropped it onto his laptop, and were able to successfully build and deploy code. My team is heavily anticipating the roboRIO for 2015 and the presumed new build tools that come with it.
Unread 14-01-2014, 11:56
Programming Mentor
AKA: Joe S
^This
Unread 16-01-2014, 14:57
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
I had the exact same problem. I was able to get it to work by running the installer in Windows 7 compatibility mode, though it may have taken a few tries.
