Thread Tools |
Rating:
Display Modes |
Re: Applying the JVN calculator using multiple motors and Mecanum
The stall current of the combination is the sum of the individual stall currents. But the free speed of the combination is not as simple. Follow the link in this post for the formula for free speed: http://www.chiefdelphi.com/forums/sh...8&postcount=64 Note: since the free speeds of the CIM and miniCIM are so close, the free speed of the combination will be roughly the average of the two. |
One can put, for example, an 11 tooth pinion on the Mini-CIM and a 12 tooth on the CIM to even out the speeds a bit. Then you have to adjust for that in the math before you combine them. If you're saying the pinion gear is a 12 tooth in your gear ratio math, Multiply the Mini-CIM's stall torque by 12/11 and its free speed by 11/12 before combining them with the CIM stall torque and free speed.
For a simplistic, proof of concept ballpark, you could run the spreadsheet with two CIMS, then two minis, and average the results.
Our last experience of combining motors was with 1CIM+1 775(with cimulator) per trans, worked well. I'd agree with Chris above. We considered testing and programming different values to the two motors, but in the end just sent them the same values. Last edited by Dad1279 : 14-01-2014 at 13:13. |
But to be clear, it's not true for motors with substantially different free speeds: the higher-speed motor may be at risk of overheating. |
Paul Coipoli did write a spreadsheet with the motor combination equations in the thread that Ether linked earlier:
http://www.fightingpi.org/Resources/...culations.xlsm His MSC seminar also discusses the topic (link skips straight to the motor combining section): http://www.youtube.com/watch?feature...xpYnqJ8#t=1479 |
#7
It seems that question (1) has been definitively answered. Add the stall currents together to get the stall current of the 2-motor system.
I am curious about questions (2) and (3) though. Is that the value of CoF that is needed for this problem? On the AndyMark website, the forward/backward CoF is listed as 0.7 for mecanum wheels. Is that implied to be on FRC carpet? None of the plaction wheels have static CoFs listed, but all of the Rubber Treaded Wheels do. If 0.7 is correct, and if you are not worried about drawing too much current, I think that you should gear it to be faster since you're not gaining any more pushing power. On the same topic, does this mean that the max pushing force of ANY normal (i.e. with wheels) robot is ~155 pounds, assuming 155 lb robot, 0.93 carpet efficiency, and 1.07 CoF? I understand that many teams use their low gear so that their robot does not draw too much current, but having that upper bound on pushing ability is interesting. |
#8
Does that mean both of my calculations in parts 2 and 3 of my question are wrong? |
#10
In the drivetrain acceleration model located here, rolling resistance is modeled with a constant parameter Kro and a speed-dependent parameter Krv. Last edited by Ether : 16-01-2014 at 11:53. |
#11
That .93 number is straight from the JVN spreadsheet. It is discussed here but again the OP in this thread is not entirely sure where it came from.
Sorry for resurrecting a dead thread, but I've been curious how the motor combinations in the JVN spreadsheet (CIM + MiniCIM, etc.) were derived. They don't quite match up with Paul's spreadsheet. Unfortunately, there aren't any formulas in the JVN spreadsheet.
#13
I actually meant to delete those out before I published it. Those are "close enough, but not very good" numbers. ![]() |
#14
It does 2 and 3 motor gearboxes and also allows you to take a snapshot at any particular speed condition. One other subtle thing it does is allow you to put your entire gearbox gear ratio into the input section so the combined motor equation is your actual gearbox output equation. |
