Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 13-01-2014, 23:31
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
2073 Pneumatic Catapult
Height, distance, check. It scores!
Through various modifications and experiments, we have found a shooter design we are confident in. Minor adjustments here and there can be made to achieve extra distance or height.
http://www.youtube.com/watch?v=I9KXe...ature=youtu.be
When weighted to the floor, with a pair of size 12 feet, it transfers even more energy into the ball.
Unread 13-01-2014, 23:35
pfreivald's Avatar
AKA: Patrick Freivald
Re: 2073 Pneumatic Catapult
Lookin' good!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-01-2014, 09:47
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
What are the specs on the cylinder? Specifically bore and stroke length...
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 14-01-2014, 12:16
billbo911's Avatar
Really good question!
After trying a Bimba 178 (1.5"dia. X 10" stroke) we found we just didn't have enough height or distance out of our system. We run it at 60 psi which produces 106 Lb. of force.
So, our next thought was that the force was sufficient, but we needed more speed out of the cylinders. So, to maintain the force, we substituted in two Bimba 0910 (1 1/16"dia X 10" stroke). This yields the same 106 Lb. of force at 60 psi, and moves a lot faster.
An additional note here is that we are using low pressure storage tanks between the valve and cylinder. One per cylinder. This is done to maximize air flow to the cylinder by not restricting it as it flows through the valve.
Unread 14-01-2014, 12:33
Birdie048 Birdie048 is offline
FRC #3459
Birdie048 is an unknown quantity at this point
Great addition. We were running into the same problem.
Thanks!
Unread 14-01-2014, 13:20
JohnFogarty's Avatar
AKA: @doctorfogarty
What valve are you using on there?
John Fogarty
Unread 14-01-2014, 13:36
billbo911's Avatar
Honestly, I do not have the specific part number. The best way to describe it is The standard double solenoid valve from the KOP from previous years. You can also purchase them from VexPro right here. Their part # is 217-2948.
That said, in the configuration we are using it, it really doesn't matter what specific solenoid valve is being used. While the cylinders are extending, very little air is actually flowing through the valve.
Unread 14-01-2014, 14:11
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Does this really work? Isn't the valve restricting the flow for everything "downstream" regardless of the volume?
Unread 14-01-2014, 14:26
billbo911's Avatar
Here are some additional details to help explain why it works.
Each cylinder (1 1/16" dia X 10") has a displacement volume of 8.87 in.^3. Each cylinder also has an accumulator tank (2"dia X 6"lng.) in line between it and the valve. The accumulator tanks have a capacity of 18.87 in.^3.
The cylinders are actually only retracted to 2/3 of their total length when the catapult is in the load position. The valve is then opened to allow the accumulators and cylinders to precharge up to 60 psi. The catapult is actually in a below top dead center (TDC) position, thus causing the arms to be forced against the stops and not allowing the arms to move. (There is the secret).
To launch, we just use a small dia. cylinder, or our hands during testing and in the video, to lift the catapult arms into an above TDC position, the rest is history.
So, as you can see, the air through the valves really doesn't move the cylinders during launching, it's the air in the accumulators that does.
BTW, this is not our original idea. We learned it in 2008. We have just modified it to our needs in this game. I wish I knew which team used this back then so we could give credit where it is due.
Unread 14-01-2014, 14:35
pfreivald's Avatar
We didn't get to really test it yesterday, but plan to test exactly that today--we built a pneumatic test board with that in mind. If I haven't posted something by tomorrow afternoon, somebody please bug me and I'll post up our results.
Team 1551
I write books, too!
Unread 14-01-2014, 14:43
wilsonmw04's Avatar
Coach
We get a similar effect with a different mechanic. I'll throw a collector in line with it tonight and take a before and after video so we can compare. I'm rather interested to see if it works.
Unread 14-01-2014, 16:37
AKA: @doctorfogarty
I'm no master with Pneumatics, but could you draw a small diagram, OR take a picture of how you have it tubed together once you've tested it successfully? This could really prove useful to a couple of teams down here in South Carolina.
John Fogarty
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Fascinating, I never thought of doing it this way. I want to try this now (I'll give you credit, hah).
I assume the tubing diagram would look like this:
Compressor --> Upstream Accumulator (115 psi) --> Regulator --> Valve --> Downstream Accumulator (60 psi) --> Cylinder
T-junction connecting both the downstream accumulator and cylinder to the valve.
Mechanism it's supporting is against a hard stop with a pivot latch, and a second piston on its own valve connected to extend, retract the latch
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 14-01-2014, 16:49
billbo911's Avatar
T-junction connecting both the downstream accumulator and cylinder to the valve......
Absolutely correct!
One note:
To maximize the air flow from the downstream accumulators to the cylinders, use double ended accumulators and feed into one end, putting the "T" between the valves and accumulators, then run the hose from a straight fitting on the other end of the accumulator into the cylinder, also with a straight fitting. Avoid using the 90deg fittings if possible.
Unread 14-01-2014, 16:57
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Funny, we had almost the same setup for prototyping and we were able to get it with the one piston(1.5in bore and 10 in stroke)
