Go to Post Our team calls me "John Regular Neun," because John V-Neun is so spectacular! - John Neun [more]
Unread 14-01-2014, 12:59
Chris is me's Avatar
AKA: Pinecone
Re: Applying the JVN calculator using multiple motors and Mecanum
Originally Posted by Nemo View Post
One can put, for example, an 11 tooth pinion on the Mini-CIM and a 12 tooth on the CIM to even out the speeds a bit. Then you have to adjust for that in the math before you combine them. If you're saying the pinion gear is a 12 tooth in your gear ratio math, Multiply the Mini-CIM's stall torque by 12/11 and its free speed by 11/12 before combining them with the CIM stall torque and free speed.
From my experience, the motors actually seem to run a bit better with the same pinion on each motor. Matching the free speeds is less essential than common wisdom would have you believe - at operating speeds / torques the motors match quite well with the same gear ratio.
