Re: 4 motors, 2 motor controllers?
I think they just wanted to save on the cost of 2 Victors/talons/jaguars
Question: if you are using the KOP tough box mini and both the motors on one sides are linked together by the PWM splitter, won't they be turning in the same direction? Because the gearbox needs one clockwise and the other counterclockwise in order to work? I assume I am missing something as lots of teams must use them...
You can reverse the direction of a DC motor by swapping the polarity of the power leads.
(see attachment) |
Ohh my.... Well I guess we happened to accidentally invert the power leads on two of our victors and then have the code work perfectly with a motor inverted on each side. I am feeling pretty dumb right now
Thanks you guys |
