Go to Post Whether we realize it or not, we've all been touched by the works of Dr. Kamen - through his TED talks, through his research and scores of publications in pediatric oncology, or perhaps more directly through his daughter. What an incredible life, what an incredible legacy. - Taylor [more]
Unread 14-01-2014, 16:31
Hoffer5236's Avatar
Hoffer5236 Hoffer5236 is offline
Project Manager
AKA: Matthew Hoffer
FRC #5236 (Man O' War)
Hoffer5236 is on a distinguished road
5236 Piston Catapult
This catpult is in the early stages, as we are an inexperienced rookie team, so we are looking for any suggestions you may be able to provide.
We are currently working on making it shorter, as it does not currently fit size requirements, but the viedo is helpful in showing our progression.
The cylinders we are using are 1.5in bore, but I'm not sure on the stroke.
Only the last shot is using the selenoids, all the others use the straight air compressor. All previous shots with the air compressor were at 60psi.
http://www.youtube.com/watch?v=r-9v9loC2As
Unread 14-01-2014, 21:20
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: 5236 Piston Catapult
Looks pretty good to me! I would continue to play with the position of your cylinders' attachment points to find a sweet spot for throwing. Be sure to test over and over again, and continue using the solenoid to mimic the robot as much as possible. If it were me, I would try rigging up some storage tanks and regulators to see how much air you are using with the components that will be on the robot and then you can get a real idea of performance as you start to scale down your launcher. That first shot looked a lot like ours!
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 14-01-2014, 21:46
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
Good job. if you want to get more out of it remember that all cylinders retract with less force then they extend with due to the rod taking up part of the area the air pushes on to retract, while extending it has full force
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 14-01-2014, 21:48
azcalg's Avatar
azcalg azcalg is offline
FRC #1212 (Sentinels)
azcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the rough
I almost pointed this out but it looks like they switched it in that last shot
Unread 15-01-2014, 06:12
Hoffer5236's Avatar
Project Manager
AKA: Matthew Hoffer
That was the only video we had of that configuration, but we did fire from the same side of the axle as the ball. It did work better, but now we have to deal with the angle of attack for the pistons.
Unread 15-01-2014, 12:39
KevinG KevinG is offline
Chesapeake LRI/Friendly Giant
AKA: Kevin
FRC #3650 (RoboRaptors)
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
Make sure you calculate how much air you're using every time you fire that, and verify that your reservoirs will have enough for however many shots you intend to make. Otherwise keep up the good work, it looks like a solid design that should serve you well.
Unread 15-01-2014, 20:54
yash101 yash101 is offline
AKA: null
Great job! It works .
This is why I like rookie teams. They can do BIG things from the SMALL number of resources available to them when starting up!
Kudos to you and keep up the work
