Go to Post note to self: MUST try harder to be funnier... - dlavery [more]
Unread 12-01-2014, 20:00
magnets's Avatar
magnets magnets is offline
Cantilevered Wheel Shaft Strength
Our team is strongly considering going for a west coast style drive where the wheel shafts are cantilevered, but we're a little worried about strength, and how to make it stronger and we were wondering if any teams could speak to the strength(or weakness) of a system like this.
We are still deciding on if we will be using dead/live axles. I am leaning towards dead axle because I feel that placing a thick block of aluminum inside of some box tubing and putting a 1/2" aluminum shaft (maybe steel?) shaft will be stronger than supporting the shaft with bearings.
So my question is- Are cantilevered wheel shafts really strong enough?
Unread 12-01-2014, 20:09
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Cantilevered Wheel Shaft Strength
We use a west coast setup with the 1/2inch aluminum hex shafts from vexpro. our robot twice fell 4 feet off the tower last year onto the wheels. the wheel shafts were fine.
Unread 12-01-2014, 20:10
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
I cannot speak from personal experience but I can tell you that teams (254 and 118 come to mind) have been running cantilevered shafts for years with great success. I would look at their past robots, the VEXPro VersaChassis and some of the chassis offered by 221 Robotic Systems for reference - plus I know there are a number of people on this forum who can give you a little more detail.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 12-01-2014, 20:21
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We have used direct drive two or three times, in each case with a live shaft off an AM Toughbox tranny. We have had no problems with the drive.
Unread 12-01-2014, 20:38
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I know a few bots with cantilevered 1/2" aluminum tube axles. Yeah, they are.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 14-01-2014, 16:35
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
The team to ask is 254. They've done this since 2004, and have won around 20 regionals with this setup. I can't speak for them, but I'm pretty sure that if strength was an issue, they wouldn't use a drive that is too weak for 10 consecutive years.
What I would be interested in knowing is how often these teams change out their wheel shafts or tread.
Unread 14-01-2014, 16:41
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Vaguely they are strong enough. We use 1/2 inch bolts for dead axles on either end and a hex 1/2 inch steel shaft for the center. If you want, I already have a CAD model (Inventor) of our WCD drivetrain that I can send you to give you a starting place.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 14-01-2014, 18:31
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Keep the length of the cantilever as short as possible. Avoid notches, holes, diameter changes, or other stress concentrations in the cantilevered portion of the shaft. .5" round or hex steel (4140) is pretty darn safe. If you're going to use aluminum you should do some math (Google for cantilevered beam equations and allowable stresses for your shaft material). Hint: wcproducts.net has some nice 7075-T6 .5" hex shaft stock available.
-Joel
Unread 14-01-2014, 18:32
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Tread: a lot. Wheel shafts: Never.
2001-2004: Team 100
2006-Present: Team 254
