Go to Post No disclaimer on earth lets you disassociate yourself with your team or what you represent because you want to say something not particularly nice, but lets you be associated again when you want to say something to encourage others, etc. - Amanda Morrison [more]
Unread 14-01-2014, 14:27
walterev walterev is offline
FRC #1758
walterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to all
Re: CRio II will not communicate
Thanks y'all.
I'll try these suggestions tonight and if not successful will call NI.
We normally don't start with these activities until week 6, so this is real progress.
Unread 14-01-2014, 16:33
minhnhatbui's Avatar
minhnhatbui minhnhatbui is offline
FRC #3990 (Tech for Kids)
minhnhatbui is a jewel in the roughminhnhatbui is a jewel in the roughminhnhatbui is a jewel in the rough
We had the same issue. Using the old 2013 imaging tool, but putting the 2014 image file (.zip file) in C:\WindRiver\WPILib\cRIO_Images and selecting it in the FRC Imaging Tool resolved the issue.
My guess is that the 2014 Imaging tool is flawed or has a bug.
Mentor for Équipe Team 3990: Tech for Kids
www.team3990.com | facebook.com/team3990 | @team3990
Regional Winners, Montréal 2012, 2013, 2014
Finalists, NY Tech Valley 2014
Semi-finals, Curie 2013
Rookie All-Star, Championship 2012
Unread 14-01-2014, 16:39
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Originally Posted by 1024Programming View Post
We reset (holding the reset button to put it in safe mode) the CRio several times and unfortunately it did not restore our ability to communicate.
One thing we did not try is removing power from the CRio and then holding the reset button as we power up the CRio. Any chance that is what you did to restore communication?
Thanks!!
Yes. This has worked for us.
Also, you should try changing the ip of your computer (just in case you have the same address as the cRIO), and DISABLE ALL OTHER NETWORK ADAPTERS!! If you have wi-fi on, it doesn't usually reconnect.
Also, if this doesn't work, go to device manager, go to the settings for your network adapter, and turn off all power saving features.
Unread 14-01-2014, 19:48
AKA: Brad
#0190 ( Gompei and the Herd)
Can you confirm that you're following these steps:
http://wpilib.screenstepslive.com/s/...ging-your-crio
Brad
Brad Miller
Robotics Resource Center
Unread 14-01-2014, 22:22
FRC #1758
Here's some feedback: switching to Safe mode for an initial format took care of my problem. Thanks Dave and everyone else.
Onward in this great journey...
Unread 15-01-2014, 13:50
1024Programming 1024Programming is offline
FRC #1024
1024Programming is an unknown quantity at this point
Brad
Yes. This is the exact site we used.
Unread 18-01-2014, 10:25
FRC #1024
We have re-established connection to the cRIO but now we are getting an error that says, "Timeout while waiting for reboot"
