Go to Post "The world is not idiot-proof. Pay Attention." - DonRotolo [more]
Unread 13-01-2014, 23:55
Jengles's Avatar
Jengles Jengles is offline
FRC #4753 (Bexley Lions)
Jengles will become famous soon enough
Physics/Engineering/Math Problem
Currently I am trying to solve for the maximum amount of force a 16" stroke of a piston could take sideways before it were to break. I'm kind of clueless where to begin.
Unread 13-01-2014, 23:58
Re: Physics/Engineering/Math Problem
Let me guess: you want to use the cylinder rod as a side-loaded latching mechanism for your kicker/catapult.
Unread 14-01-2014, 00:13
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
If this is actually why you're asking, our team did this on a mechanism in a previous year. I recommend not using the shaft as the locking mechanism, but thread an extension on made out of grade 8 material, then support it as closely as possible on both ends.
"break" is a loosely defined term. Typically it would mean fracture, but in the case of a rod extension from a piston, any permanent deformation (yielding) from bending, or something biting into the shaft would be detrimental to the future operation of the shaft.
If you know the bending moment on the shaft, you could use the formula sigma=M*c/I where c is the radius, and I is the second moment of area. I=pi/2*r^4. Then compare the stress value (sigma) against the yield limit of the steel in the rod extension.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 14-01-2014, 00:20
Jengles's Avatar
What is M?
Unread 14-01-2014, 00:32
MechEng83's Avatar
AKA: Mr. Cool
What is M?
M is the aforementioned "bending moment"
The formula for calculating it will depend on your endpoint support configuration, e.g. fixed-fixed, fixed-free, fixed-pinned, pinned-pinned (pinned-free and free-free are dynamic cases, and the math becomes a whole lot more fun) Try here for a tutorial in calculating bending moment.
Red Alert Robotics
Unread 14-01-2014, 00:55
Jengles's Avatar
So what would the equation/set up look like for a fixed-free configuration?
Unread 14-01-2014, 10:30
MechEng83's Avatar
AKA: Mr. Cool
Assuming the load is perpendicular to the shaft, the maximum bending moment for a fixed-free setup occurs at the fixed end and is calculated by multiplying the force by the distance from the fixed point. There is no bending moment between the load and the free end.
Red Alert Robotics
Unread 14-01-2014, 16:53
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
I've attached a semi worked out solution. You should be able to plug in your numbers to these equations. I assumed the shaft is 6.35 mm or 1/4 in stainless steel. I don't know what it is actually made of but you want to look up the yield stress. Once you solve for the moment, that is equal to force applied * distance cantilevered. If you need more help just ask.
Name:	Bending of a cylinder.JPG
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 14-01-2014, 16:58
I think you should post a picture or hand-sketch of what you are proposing to do to your piston so that there is no miscommunication.
