Go to Post I see you've one-upped me in the stripped gear game. I commend you. - frcguy [more]
Unread 14-01-2014, 16:16
cvillerobotics cvillerobotics is offline
FRC #5243
cvillerobotics is an unknown quantity at this point
Will 4 CIM motors be enough...
Will 4 CIM motors be enough to power a conveyor belt to propel the 2014 FRC Game piece through a tube-like structure and shoot?
Will 4 CIM motors be enough to power a conveyor belt to shoot the 2014 FRC Game piece out of a tube?
Unread 14-01-2014, 16:28
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Re: Will 4 CIM motors be enough...
First off, Welcome to CD!
Teams have already shown prototype wheel based shooters using less power than 4 CIM motors, so I'd say that would be enough power. Whether or not YOUR design is going to work is something that is hard to answer without more detail. Personally, I'd strongly suggest you consider putting 4 CIM's on your drivetrain and look at using some of the other motors available on your shooter. There is the potential for a lot of defense this year, and an under-powered drivetrain is going to be a big disadvantage.
By the way, you may want to eliminate the empty space in your post, it makes the thread harder to read.
Unread 14-01-2014, 16:34
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Without any additional info, I'd suggest just trying it. This is what prototyping is for! Create a system that will emulate the function of the mechanism that you want on your robot and then make changes until you get it right.
If we have the same system in mind, I'd bet you one CIM would be enough. I would, however, caution you against conveyor belts as a shooting mechanism as they are very difficult to execute in a way that is reliable.
I noticed that this is your first year as a team. If you are looking for designs that are proven to work with track balls take a look at robots from the 2008 game Overdrive.
The link to the wiki on it is below
http://en.wikipedia.org/wiki/FIRST_Overdrive
For conveyer belt designs look at robots from the 2012 game Rebound Rumble, wiki listed below
http://en.wikipedia.org/wiki/Rebound_Rumble
Good luck!
Feel free to ask any questions that you might have
Garrett
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 14-01-2014, 16:51
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Calculate the power necessary and compare to the CIM output power. (Hint: 4 CIMs is more than enough to move an entire robot.)
I question your willingness to allocate 4 of your 6 CIMs to a shooter. If you can, you want 4 CIMs on your drive train.
Unread 14-01-2014, 16:58
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
if you us to many it may over shoot and may case disaster.
