Go to Post Are we really that close-minded that we have to insult other teams that deviate from what we percieve to be right? Giving an opinion and insulting someone are far from each other. - Amanda Morrison [more]
Unread 14-01-2014, 17:43
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Team Update 1-14-2014
Most changes should be bolded, I may have missed a few, it's hard to format
Link
General Updates
Windows 7 Activation Update:
If you've received an error while trying to activate Windows on your Classmate, please refer to the procedure for activating the Windows 7 OS, 2014 Windows 7 Activation Procedure_Rev0, which has been posted at http://www.usfirst.org/roboticsprogr...ical-resources.
In order to activate the copy of Windows 7, teams must download this tool and run the application.
LRI Training
On Saturday, January 11, we hosted more than 50 Lead Robot Inspectors at FIRST HQ as part of LRI Training. Many of the changes in this Team Update are a result of their feedback and are an attempt to clarify the true intent behind each rule. We thank them for their time spent as volunteers and for their feedback as we strive for continuous improvement of the Manual.
Section 3: The Game
Section 3.1: Game Details
Section 3.1.4: Scoring
The change made by Team Update 2014-01-07 to Section 3.1.4: Scoring, part A created unintended consequences for exactly when a BALL would be considered SCORED in a GOAL. The intent was to make sure that a BALL that “bounced out” of a GOAL did not count as SCORED. We believe the following change better captures that intent.
A BALL is considered SCORED in an ALLIANCE’S GOAL if
A. a ROBOT causes one (1) of their ALLIANCE’S BALLS to cross completely and remain completely through the opening(s) of one (1) of their ALLIANCE’S GOALS
B. the ALLIANCE ROBOT last in contact with the BALL was entirely between the TRUSS and their ALLIANCE’S HIGH GOALS, and
C. the BALL is not in contact with any ROBOT from that ALLIANCE.
A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or HUMAN PLAYER.
Section 3.2: Game Rules
Section 3.2.3: General Rules
G10
The following actions are prohibited with regards to interaction with FIELD elements (items A-D exclude BALLS):
grabbing,
grasping
grappling
attaching to,
damaging,
becoming entangled
Violation: FOUL. If the Head Referee determines that further damage is likely to occur, DISABLED. Corrective action (such as eliminating sharp edges, removing the damaging mechanism, and/or re-Inspection) may be required before the ROBOT will be allowed to compete in subsequent MATCHES.
Section 4: The Robot
Section 4.2: Safety & Damage Prevention
R9
Protrusions from the ROBOT and exposed surfaces on the ROBOT shall not pose hazards to the ARENA elements (including the BALLS) or people.
Section 4.4: Fabrication Schedule
R13
ROBOT elements created before Kickoff are not permitted. ROBOT elements, including software, that are designed before Kickoff are not permitted. unless they or their source files are publicly available prior to Kickoff.
Exceptions include the following:
BUMPERS,
OPERATOR CONSOLE,
battery assemblies per R5-A, and
software and designs with source files publicly available prior to Kickoff.
R14
The ROBOT (including items intended for use during the competition in alternative configurations of the ROBOT, excluding items permitted per R17 R18) must be bagged or crated (as appropriate for your event), and out of Team hands by Stop Build Day, February 18, 2014 (refer to the FRC Administrative Manual, Section 5 for more details).
Section: 4.6: BUMPER Rules
R26
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-10). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER. Additionally, any gap between the backing material and the frame
  • must not be greater than ¼ in. deep, and or
  • 8 in wide.
R27
Each ROBOT must be able to display red or blue BUMPERS to match their ALLIANCE color, as assigned in the MATCH schedule distributed at the event (reference Section 5.1.1: MATCH Schedules). Markings visible when installed on the ROBOT, other than those explicitly required per R28, are prohibited.
Section 4.8: Power Distribution
R35
The one ROBOT battery, Anderson Power Products (or APP) Connectors (p/n SB50), the one main 120-amp (120A) circuit breaker (Cooper Bussman P/N: CB185-120), and the one Power Distribution (PD) Board shall be connected as shown in Figure 4-11.
R51
Each power regulating device may control electrical loads per Table 4-4. Unless otherwise noted, each power regulating device may control one and only one electrical load.
Table 4-4: Legal Power Regulating Device Use
Electrical Load
Jaguar, Victor, or Talon motor controller
Spike H-Bridge Relay
VEX Motor Controller 29
Solenoid Breakout
M3-RS390-12
M3-RS395-12
M5-RS545-12
M5-RS555-12
M7-RS775-12
262100-3030
262100-3040
ARA motors
AE235100-0610
am-2235
am-2161
am-2194
R86
If the regulator is kept off-board the ROBOT with the compressor, then only low-pressure (60 psi or less) “working” air can be stored on the ROBOT. The “working” pressure gauge must be installed on-board the ROBOT at all times (Figure 4-17).
Figure 4-17: (Updated to match rule) Off-Board Compressor, Regulator, and Gauge with Additional On-Board Gauge
Section 5: The Tournament
Section 5.5: Tournament Rules
Section 5.5.2: Eligibility and Inspection Rules
At each event, the Lead ROBOT Inspector (LRI) has final authority on the legality of any COMPONENT, MECHANISM, or ROBOT. Inspectors may re-Inspect ROBOTS to ensure compliance with the rules.
ROBOTS are permitted to participate in scheduled Practice MATCHES prior to passing Inspection. However, the FTA, LRI or Head Referee may determine at any time that the ROBOT is unsafe, per Section 3.2.1: Safety, and may prohibit further participation in Practice MATCHES until the condition is corrected and the ROBOT passes Inspection.
ROBOTS without BUMPERS will be considered unsafe.
ADDED BLUE BOX
If a ROBOT cannot report for a MATCH, the Lead Queuer should be informed and at least one (1) member of the TEAM should report to the ARENA for the MATCH to avoid receiving a RED CARD, with the exception of a Team that has not passed Inspection, per Rule T6.
T12
Power and air pressure should only be enabled on the ROBOT during those portions of the Inspection process where it is absolutely required to validate certain system functionality and compliance with specific rules (firmware check, confirmation of safe release of stored energy up to and including actuation of the mechanism, etc.).
Section 6: The Glossary
CATCH: the event when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or a HUMAN PLAYER.
SCORE: to accrue points for an ALLIANCE as described in Section 3.1.4: Scoring.
Unread 14-01-2014, 17:48
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Team Update 1-14-2014
Originally Posted by DevenStonow View Post
They changed the definition of "CATCH" to allow robots to gain points by catching their own ball
I read that as the opposite. They added a restriction to "CATCH" that the ball may not even contact the robot that scored the TRUSS. Previously, you could have touched the ball you threw over the truss without possessing it and still score the catch if your alliance partner proceeded to possess the ball before it touched the carpet.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 14-01-2014, 17:50
AKA: Scooby
My bad, you're right, I misread it.
Unread 14-01-2014, 17:55
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
This clarification eliminates the possibility of a robot "Catching" their own truss toss then passing the ball to a partner (before touching the carpet) to earn the Catch bonus.
No surprise here...
Unread 14-01-2014, 18:26
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Though it doesn't say it can't touch an opposing alliance member... does that seem valid?
Blue1 passes over TRUSS, it bounces off Red1 and into Blue2's possession, without ever touching the carpet. Does that count as a CATCH?
Unread 14-01-2014, 18:27
GaryVoshol's Avatar
Cogito ergo arbitro
Good thing they did that, because there was a discontinuity between an earlier Q&A that said the throwing robot couldn't catch it first, and the rule that didn't prohibit it until now.
(since 2004)
Unread 14-01-2014, 19:32
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
Isn't R26 prohibiting West Coast drive trains?
Unread 14-01-2014, 19:34
Nope. Most WCDs have wheels smaller than 8"; 4" is typical.
Unread 14-01-2014, 19:45
Team Role: CAD
yeah, but the gap would be deeper than 1/4 in
Unread 14-01-2014, 19:50
That's an OR in R26, not an AND. So the gap must not be greater than 1/4" deep OR 8" wide. Also reference Figure 4-10.
Translation: if you have a gap that is BOTH deeper than 1/4" AND wider than 8", you have a problem. Otherwise, you should be OK.
Unread 14-01-2014, 19:56
Team Role: CAD
now that i've seen the image i understand what you're saying, it must be wider and deeper, yet the rule says wider or deeper they should change either the image or the rule
Unread 14-01-2014, 20:13
Yep, and they changed AWAY from that very wording! C'mon, GDC!
Unread 14-01-2014, 22:00
magnets's Avatar
magnets magnets is offline
The text "CATCH: the event when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or a HUMAN PLAYER."
can mean two things
1.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT'S ALLIANCE partner is POSSESSED by"
a.) "that ROBOT before contacting the carpet"
b.) "the ROBOT which SCORED the TRUSS"
c.) "or a HUMAN PLAYER"
2.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the"
a.) "carpet"
b.)"the ROBOT which SCORED the TRUSS"
Two is more likely, but it's still really ambiguous.
Unread 15-01-2014, 12:15
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
can mean two things
a.) "carpet"
Since 1b and 1c would allow for a CATCH to be awarded regardless of whether or not the BALL had touched the carpet, which is logically not how this is supposed to work, I believe option 2 is likely what they meant. It would be clearer if they had put the word "either" after the word "contacting", but they didn't. They probably figured that we would realize that the BALL is no longer eligible for CATCH points once it contacted the ground, thus eliminating interpretation 1 as an option.
EDIT: If grammar and syntax rules are relaxed there is actually at least one more possible interpretation:
3.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT'S ALLIANCE partner is POSSESSED by that ROBOT before contacting"
-a.) "the carpet"
-b.) "the ROBOT which SCORED"
---i.) "the TRUSS or"
---ii.) "a HUMAN PLAYER"
However this can logically be ruled out given that one cannot (legally) SCORE a HUMAN PLAYER .
Unread 15-01-2014, 17:33
magnets's Avatar
-a.) "the carpet"
I can't wait until a team builds a human-player-throwing-robot!
