Go to Post We need to start building FIRST competition arenas and leasing them in the off-season to the sports teams and conventions ;) - protoserge [more]
Unread 14-01-2014, 18:13
zach441's Avatar
zach441 zach441 is offline
FRC #4302 (Robophins)
zach441 is an unknown quantity at this point
Question on rule <R3>
As per rule <R3(D)>An extension above 60 inches must fit within a 6 inch vertical cylinder.
Is it allowed for a part within this cylinder to flex outside of it when hit?
Unread 14-01-2014, 18:16
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Question on rule <R3>
Theoretically flex would not be allowed. You should build your robot robust enough that it will be in compliance.
But since an opponent cannot force you into a foul, in practice it would be unlikely to be called. (Unless it was your own alliance that bumped it outside the cylinder.)
(since 2004)
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
in my interpretation, yes so long as it is not intentionally designed to flex. But it shouldn't. What would you put up there that would flex? you don't want to be playing goalie with something flexible, you want something hard to bounce the ball back out.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 14-01-2014, 18:20
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Ask on Q&A. (Though I suspect their answer will be along the lines if "The 6-inch cylinder constraint is always in effect regardless of the state of the robot parts inside it.")
Unread 14-01-2014, 21:55
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
I agree, if designed to flex then FRC might deem that Strategic because the design is specifically made to break a rule on a technicality.
Usually their strategic penalty is along the lines of Technical Foul, or if the rule already has a technical foul penalty, then a Red Card.
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
