Go to Post My brain is borderline mush, I don't have much of a voice, and I don't think I could be much happier. - Billfred [more]
Unread 14-01-2014, 18:27
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Team Update 1-14-2014
Good thing they did that, because there was a discontinuity between an earlier Q&A that said the throwing robot couldn't catch it first, and the rule that didn't prohibit it until now.
(since 2004)
Unread 14-01-2014, 19:32
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
Isn't R26 prohibiting West Coast drive trains?
Unread 14-01-2014, 19:34
Nope. Most WCDs have wheels smaller than 8"; 4" is typical.
Unread 14-01-2014, 19:45
Team Role: CAD
yeah, but the gap would be deeper than 1/4 in
Unread 14-01-2014, 19:50
That's an OR in R26, not an AND. So the gap must not be greater than 1/4" deep OR 8" wide. Also reference Figure 4-10.
Translation: if you have a gap that is BOTH deeper than 1/4" AND wider than 8", you have a problem. Otherwise, you should be OK.
Unread 14-01-2014, 19:56
Team Role: CAD
now that i've seen the image i understand what you're saying, it must be wider and deeper, yet the rule says wider or deeper they should change either the image or the rule
Unread 14-01-2014, 20:13
Yep, and they changed AWAY from that very wording! C'mon, GDC!
Unread 14-01-2014, 22:00
magnets's Avatar
magnets magnets is offline
The text "CATCH: the event when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or a HUMAN PLAYER."
can mean two things
1.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT'S ALLIANCE partner is POSSESSED by"
a.) "that ROBOT before contacting the carpet"
b.) "the ROBOT which SCORED the TRUSS"
c.) "or a HUMAN PLAYER"
2.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the"
a.) "carpet"
b.)"the ROBOT which SCORED the TRUSS"
Two is more likely, but it's still really ambiguous.
Unread 15-01-2014, 12:15
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is online now
AKA: Alan Wells
FRC #1350 (Rambots)
can mean two things
a.) "carpet"
Since 1b and 1c would allow for a CATCH to be awarded regardless of whether or not the BALL had touched the carpet, which is logically not how this is supposed to work, I believe option 2 is likely what they meant. It would be clearer if they had put the word "either" after the word "contacting", but they didn't. They probably figured that we would realize that the BALL is no longer eligible for CATCH points once it contacted the ground, thus eliminating interpretation 1 as an option.
EDIT: If grammar and syntax rules are relaxed there is actually at least one more possible interpretation:
3.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT'S ALLIANCE partner is POSSESSED by that ROBOT before contacting"
-a.) "the carpet"
-b.) "the ROBOT which SCORED"
---i.) "the TRUSS or"
---ii.) "a HUMAN PLAYER"
However this can logically be ruled out given that one cannot (legally) SCORE a HUMAN PLAYER .
Unread 15-01-2014, 17:33
magnets's Avatar
-a.) "the carpet"
I can't wait until a team builds a human-player-throwing-robot!
