Team Update 1-14-2014
Most changes should be bolded, I may have missed a few, it's hard to format
Link Quote:
Re: Team Update 1-14-2014
I read that as the opposite. They added a restriction to "CATCH" that the ball may not even contact the robot that scored the TRUSS. Previously, you could have touched the ball you threw over the truss without possessing it and still score the catch if your alliance partner proceeded to possess the ball before it touched the carpet.
This clarification eliminates the possibility of a robot "Catching" their own truss toss then passing the ball to a partner (before touching the carpet) to earn the Catch bonus.
No surprise here... |
Though it doesn't say it can't touch an opposing alliance member... does that seem valid?
Blue1 passes over TRUSS, it bounces off Red1 and into Blue2's possession, without ever touching the carpet. Does that count as a CATCH? |
Good thing they did that, because there was a discontinuity between an earlier Q&A that said the throwing robot couldn't catch it first, and the rule that didn't prohibit it until now.
#7
Isn't R26 prohibiting West Coast drive trains?
#8
Nope. Most WCDs have wheels smaller than 8"; 4" is typical.
#9
yeah, but the gap would be deeper than 1/4 in
#10
That's an OR in R26, not an AND. So the gap must not be greater than 1/4" deep OR 8" wide. Also reference Figure 4-10.
Translation: if you have a gap that is BOTH deeper than 1/4" AND wider than 8", you have a problem. Otherwise, you should be OK. |
#11
they should change either the image or the ruleLast edited by Henrique Schmit : 14-01-2014 at 20:00. |
#12
Yep, and they changed AWAY from that very wording! C'mon, GDC!
#13
The text "CATCH: the event when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or a HUMAN PLAYER."
can mean two things 1.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT'S ALLIANCE partner is POSSESSED by" a.) "that ROBOT before contacting the carpet" b.) "the ROBOT which SCORED the TRUSS" c.) "or a HUMAN PLAYER" --------------------------- 2.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the" a.) "carpet" b.)"the ROBOT which SCORED the TRUSS" c.) "or a HUMAN PLAYER" Two is more likely, but it's still really ambiguous. |
#14
EDIT: If grammar and syntax rules are relaxed there is actually at least one more possible interpretation: 3.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT'S ALLIANCE partner is POSSESSED by that ROBOT before contacting" -a.) "the carpet" -b.) "the ROBOT which SCORED" ---i.) "the TRUSS or" ---ii.) "a HUMAN PLAYER" However this can logically be ruled out given that one cannot (legally) SCORE a HUMAN PLAYER .Last edited by PAR_WIG1350 : 15-01-2014 at 12:22. |
#15
