Go to Post You must have a base on which to stand. Knowledge is the base that wisdom stands on. - Steve W [more]
Unread 14-01-2014, 20:14
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
Re: Placing a Tank after a solenoid valve
Originally Posted by Ed Sparks View Post
I see a potential problem with this device depending on how the system is pneumatically controlled. The cylinder may be considered a second compressor if it restores the air used to push the plunger back into the storage devices when the plunger is re-cocked. In this case, I'm assuming something mechanical is re-cocking the cylinder. A solenoid valve would have exhausted the air to atmosphere in both the forward stroke and reverse stroke.
The cylinder retracted with gravity/a small spring, the valve was open in this condition so the pushed air never re-entered the system
EDIT: Also we've found that in a system like this it's vital to not have any fittings on the other end of cylinder
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
