Go to Post If it is good enough for Paul and JVN it's good enough for me. - Vikesrock [more]
Unread 14-01-2014, 17:36
WaterClaw's Avatar
WaterClaw WaterClaw is offline
Comandante
AKA: Andrew A. Matthews
FRC #2512 (Duluth East Daredevils)
Team Role: Tactician
WaterClaw is on a distinguished road
Re: 2073 Pneumatic Catapult
Originally Posted by billbo911 View Post
Height, distance, check. It scores!
Through various modifications and experiments, we have found a shooter design we are confident in. Minor adjustments here and there can be made to achieve extra distance or height.
http://www.youtube.com/watch?v=I9KXe...ature=youtu.be
When weighted to the floor, with a pair of size 12 feet, it transfers even more energy into the ball.
Well done. It seems reasonably accurate.
Insanity is correlative only to the standards of a culture. Cultures are often defined by their technology. Technology only advances by the efforts of those who would be considered insane. So thank your local FIRST team for advancing society.
Unread 14-01-2014, 17:56
Here are some additional details to help explain why it works...
The cylinders are actually only retracted to 2/3 of their total length when the catapult is in the load position. The valve is then opened to allow the accumulators and cylinders to precharge up to 60 psi. The catapult is actually in a below top dead center (TDC) position, thus causing the arms to be forced against the stops and not allowing the arms to move. (There is the secret).
To launch, we just use a small dia. cylinder, or our hands during testing and in the video, to lift the catapult arms into an above TDC position, the rest is history.
Is the attached sketch a correct representation of what you are describing?
The blue line represents the launcher, the brown block represents the stops in the loaded position. The black circles are the pivot points.
In the loaded position (as shown), the launcher is being pressed against the stops. An upward force at the green arrow will move pivot2 above the line connecting pivot1 and pivot3, and the rest, as you said, is history.
Unread 14-01-2014, 18:13
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Although the positions of the pivots aren't exactly where ours are, because of mechanical mounting options, functionally your picture and description are correct.
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
How are you reloading this? Once the cylinders are retracted don't they need to be forced into a locked position again?
Unread 14-01-2014, 18:17
If the launcher is heavy enough gravity could pull it over-center into the locked position. Once it's over-center, then you charge the cylinder to arm it.
Just guessing here.
Unread 14-01-2014, 18:19
billbo911's Avatar
We use Pixie Dust!
Sorry, it just seemed like the right answer at the moment.
Because of the mechanical mounting offset provided by the mounting hardware, and the wonderful force of gravity, the arms cause the system to fall below TDC when the system is retracted and then recharged. This causes the system to be locked once again, waiting to be fired.
EDIT: Ether beat me to it.
Unread 14-01-2014, 20:58
pfreivald's Avatar
AKA: Patrick Freivald
Clever. Our pneumatapult failed quite well this evening. I'll have to try this when we meet on Thursday!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-01-2014, 21:07
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
ours is ALMOST there. We have a range of 4-13ft mostly... at 9-10 ft, our shot is just a tad too high. We need to flatten out the trajectory just a bit and we have it set.
I tried the collector and I didn't notice a difference. Then I read the thread and saw we needed one on each side of the piston. We will try that Thursday.
Unread 14-01-2014, 21:42
pfreivald's Avatar
Mr. Bill, am I correct, then, in deducing that you have to recharge the cylinder and the accumulator entirely after every shot?
Team 1551
I write books, too!
Unread 14-01-2014, 21:52
billbo911's Avatar
Yes, this is true.
Honestly, the cycle time between shots may be a bit long. Although, if our estimation is correct, the amount of time between shots in this game "should" be enough to recharge.
Although, you could add a large high pressure storage volume to help compensate for that, too.
Unread 14-01-2014, 22:18
pfreivald's Avatar
Yes, this is true.
I'm thinking "maybe three shots in autonomous = two second or less reload time required". At least that once.... Lots of air tanks may be in our future!
Team 1551
I write books, too!
Unread 14-01-2014, 22:33
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
The thing that I worry about with piston launching is that shots may become unreliable with varying air pressure and the possible need for tanks to hold enough air for multiple fires. What benefit is there of this method versus piston to pull catapult to fire position and surgical tubing acting as the force that throws?
My comments or views do not necessarily reflect those of any affiliated organizations or teams
Unread 14-01-2014, 22:43
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Nice! Glad to see one of our favorite teams doing well! I do worry about losing too much air pressure, but realistically the majority of this game isn't even launching the ball.
Unread 15-01-2014, 02:10
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Will you be able to vary the distance of your shot? We prototyped something similar but ultimately decided against it due to the lack of variability.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 15-01-2014, 08:32
pfreivald's Avatar
Couldn't you put in at least one retractable stop to get different shots?
Team 1551
I write books, too!
