Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 11-01-2014, 21:40
hiyou102's Avatar
hiyou102 hiyou102 is offline
hiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud of
SmartDashboard 2.0 launch issue
I've been trying to start the new javafx SmartDashboard have run into the following error why trying to launch the jar extracted from the zip:
C:\Users\TEAM 4334\sunspotfrcsdk\tools\sfx>java -jar sfx.jar
file:/C:/Users/TEAM 4334/sunspotfrcsdk/tools/sfx/sfx.jar!/jrubyfx/utils/common_c
onverters.rb:29 warning: already initialized constant ARG_CONVERTER_SUFFIX
onverters.rb:32 warning: already initialized constant NAME_TO_COLORS
onverters.rb:138 warning: already initialized constant CONVERTERS
onverters.rb:173 warning: already initialized constant ENUM_CACHE
onverters.rb:176 warning: already initialized constant ENUM_OVERRIDES
Exception running Application:
#<NameError: uninitialized constant JRubyFX::Controller::FxmlLoader>
org/jruby/RubyModule.java:2684:in `const_missing'
file:C:/Users/TEAM 4334/sunspotfrcsdk/tools/sfx/sfx.jar!/jrubyfx/imports.rb:71:i
n `const_missing'
file:C:/Users/TEAM 4334/sunspotfrcsdk/tools/sfx/sfx.jar!/jrubyfx/controller.rb:3
34:in `get_fxml_loader'
file:C:/Users/TEAM 4334/sunspotfrcsdk/tools/sfx/sfx.jar!/jrubyfx/controller.rb:1
17:in `load_into'
file:/C:/Users/TEAM 4334/sunspotfrcsdk/tools/sfx/sfx.jar!/jrubyfx/core_ext/stage
.rb:82:in `fxml'
classpath:jar-bootstrap.rb:74:in `start'
org/jruby/RubyBasicObject.java:1536:in `instance_eval'
file:C:/Users/TEAM 4334/sunspotfrcsdk/tools/sfx/sfx.jar!/jrubyfx/module.rb:49:in
 `with'
classpath:jar-bootstrap.rb:73:in `start'
file:C:/Users/TEAM 4334/sunspotfrcsdk/tools/sfx/sfx.jar!/jrubyfx/java_fx_impl.rb
:119:in `launch_app_after_platform'
org/jruby/gen/InterfaceImpl570972409.gen:13:in `run'
Any help with the issue would be appreciated. I am running windows 7 and using Java 1.7.0_13.
Team 4334 2012-2014
Unread 14-01-2014, 21:56
ktrobotcreator's Avatar
ktrobotcreator ktrobotcreator is offline
Programmer
FRC #1245 (Shazbots)
ktrobotcreator is an unknown quantity at this point
Re: SmartDashboard 2.0 launch issue
We had a very similar issue. I think the problem is the space in the Username. Can you move the sfx folder to just the C: drive so it doesn't have to go through the User account with the space? When you launch sfx it needs to make two other files, sfxlib.jar being one of them. I forget the name of the other. Even if the files exist already, the space in the Username is problematic for the system finding them.
We ended up making a different user account with a name without spaces and it worked just fine for opening. Although we haven't been able to get it to open with Driver Station. (http://www.chiefdelphi.com/forums/sh...93#post1327293)
I hope this helps!
Unread 15-01-2014, 16:35
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
(sfx dev here) hmm, thats very odd. This is the latest released build I assume? Does moving to a non-space user dir work?
Watchdog.Kill();
Unread 17-01-2014, 21:06
Peter Rivera Peter Rivera is offline
FRC #0662
Peter Rivera is an unknown quantity at this point
Yes, we also had the same problem with being unable to launch SmartDashboard 2.0. The sfx directory had the sfx.jar file, but issuing the command "java -jar sfx.jar" resulted in an error stating that the file "sfxlib.jar" was not found.
The directory path had a directory with spaces, which was being translated by java into "%20".
Moving the sfx.jar file to a directory with no spaces allowed the sfxlib.jar and sfxmeta.jar to be created, and the SmartDashboard was launched.
Also tried moving these two files into the directory that had a space, but still received the error that the sfxlib.jar file was not found, and the directory path had "%20" as the path (instead of a space), which is probably why java was unable to find the file.
Peter Rivera
Programming Mentor
RMR 662 - Rocky Mountain Robotics
Unread 18-01-2014, 16:45
hiyou102's Avatar
I moved it it to the C:// directory and got the error mentioned in this post.
Team 4334 2012-2014
Unread 26-02-2014, 22:59
riftware riftware is offline
Parent Mentor
AKA: Andrew Chandler
FRC #0031
riftware is an unknown quantity at this point
Putting this line into the FRC DS Data Storage.ini works for me - I have to switch to Java then back to default to launch it. Also it takes a second for it to show up.
DashboardCmdLine = "C:\\apps\\jdk1.7.0_51\\bin\\java.exe -jar c:\\SFX\\sfx.jar"
Things to know:
1: I installed java to the directory above so modify accordingly
2: I copied sfx.jar and plugins to a new directory called SFX right off the root of the C: drive.
