Go to Post Regardless of the next course of action, getting steamed and angry will benefit nobody. And coming from me, that has to mean something. - Lil' Lavery [more]
Unread 14-01-2014, 22:14
Wertles Wertles is offline
FRC #3044
Wertles is an unknown quantity at this point
Toughbox Mini Opinions
This year our team has decided to use the AM41U Chassis that came with the Kit of Parts. I wanted to know if using the ToughBox Mini's the Kit came with is either a good or bad idea. Our team has mixed reviews because they are plastic, but others think that since they just fix right on to the chassis, it would be simple to use them and not worry about a complex drive train. So if there are any teams with experience with these gearboxes I would gladly appreciate any input you have.
Thanks.
Unread 14-01-2014, 22:17
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Toughbox Mini Opinions
Thanks.
Don't waste time reinventing the wheel, use the ToughBox Mini's.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 14-01-2014, 22:21
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Good or bad depends on your application. I have not had any durability problems with the plastic housing of the toughbox mini's.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-01-2014, 22:29
pfreivald's Avatar
AKA: Patrick Freivald
We used them on our octocanum drive last year and had no durability issues whatsoever. We're using them again this year!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-01-2014, 22:36
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
We used them all of last year and for the beginning of this year and have had no problems with the gearboxes at all.
Unread 14-01-2014, 22:39
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
They are fine. Unless you want to swap the internal gears out to produce a different ratio, they should do just fine as-is.
That being said, as with any gearbox, It is probably a good idea to re-grease the internals at some point during the season.
Unread 14-01-2014, 22:48
FRC #3044
Will keep this in mind. We were already planning on switching out the gear ratio to the 12.1 ft/sec.
