Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Unread 15-01-2014, 00:00
ktrobotcreator's Avatar
ktrobotcreator ktrobotcreator is offline
Programmer
FRC #1245 (Shazbots)
ktrobotcreator is an unknown quantity at this point
Re: Getting Smartdashboard 2.0 working
Because you got that error and not "command not found" or something similar, I take it you did put it in a separate folder, but I'm just confirming that it does exist there?
When you try to run it, does it create two other .jars, one being sfxlib.jar?
Can you open it when you double click on it?
When you put the file/folder into the C:\\ drive, did you also copy the plugins folder that was originally with it?
Unread 16-01-2014, 19:56
hiyou102's Avatar
hiyou102 hiyou102 is offline
hiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud of
Yes it does exist there.
Yes.
Nothing. That's the reason I started opening it cmd.
Yes, I copied the plugin folder. It came empty though.
Sorry for taking so long to respond.
Team 4334 2012-2014
Unread 16-01-2014, 23:01
Programmer
What version(s) of Java do you have on your computer? For me I got it working once I uninstalled all versions of Java 6 and updated to the newest one (7 update 51).
Unread 16-01-2014, 23:04
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
Where do you even download SmartDashboard 2.0? I can't seem to find a download link for it, and all of the links on the FIRSTForge site are from last year.
Unread 16-01-2014, 23:07
Programmer
You don't need to download it separately; it comes in the sunspotfrcsdk folder that is automatically installed with the Netbeans plugins.
The directory is C:\Users\[Your_Username]\sunspotfrcsdk\tools.
It will be called sfx.zip. Extract it into another folder. I just did mine into a folder called sfx in the tools directory.
See this page for more details. http://wpilib.screenstepslive.com/s/...ch-with-the-ds
Unread 16-01-2014, 23:10
virtuald's Avatar
RobotPy Guy
Hm. Well, what if I'm not using Java? I suspect it's probably in the C++ tools then..
Yup. It's in the WPILib folder of the workbench update. Silly lack of documentation. >_>
Unread 16-01-2014, 23:13
Programmer
Sorry, I thought this was in the Java sub-forum because I was posting about SFX in another thread earlier today. It is still on the site!
"If you have the C++ update installed this is likely C:\Windriver\WPILib\SFX" Under "Locate SFX". Their pictures just show the Java path, but it works the same way.
Unread 18-01-2014, 17:08
hiyou102's Avatar
I updated to 1.7.0_51 and am now getting the follow error:
C:\>java -jar sfx.jar
file:/C:/sfx.jar!/jrubyfx/utils/common_converters.rb:29 warning: already initial
ized constant ARG_CONVERTER_SUFFIX
file:/C:/sfx.jar!/jrubyfx/utils/common_converters.rb:32 warning: already initial
ized constant NAME_TO_COLORS
file:/C:/sfx.jar!/jrubyfx/utils/common_converters.rb:138 warning: already initia
lized constant CONVERTERS
file:/C:/sfx.jar!/jrubyfx/utils/common_converters.rb:173 warning: already initia
lized constant ENUM_CACHE
file:/C:/sfx.jar!/jrubyfx/utils/common_converters.rb:176 warning: already initia
lized constant ENUM_OVERRIDES
Exception running Application:
#<NameError: uninitialized constant JRubyFX::Controller::FxmlLoader>
org/jruby/RubyModule.java:2684:in `const_missing'
file:C:/sfx.jar!/jrubyfx/imports.rb:71:in `const_missing'
file:C:/sfx.jar!/jrubyfx/controller.rb:334:in `get_fxml_loader'
file:C:/sfx.jar!/jrubyfx/controller.rb:117:in `load_into'
file:/C:/sfx.jar!/jrubyfx/core_ext/stage.rb:82:in `fxml'
classpath:jar-bootstrap.rb:74:in `start'
org/jruby/RubyBasicObject.java:1536:in `instance_eval'
file:C:/sfx.jar!/jrubyfx/module.rb:49:in `with'
classpath:jar-bootstrap.rb:73:in `start'
file:C:/sfx.jar!/jrubyfx/java_fx_impl.rb:119:in `launch_app_after_platform'
org/jruby/gen/InterfaceImpl256959397.gen:13:in `run'
C:\>java -version
java version "1.7.0_51"
Java(TM) SE Runtime Environment (build 1.7.0_51-b13)
Java HotSpot(TM) Client VM (build 24.51-b03, mixed mode, sharing)
Team 4334 2012-2014
Unread 18-01-2014, 19:27
Programmer
Is that the only version of java you have on your machine? Use the Java uninstall tool (http://www.java.com/en/download/uninstallapplet.jsp) to check and remove any previous versions.
Unread 18-01-2014, 19:32
hiyou102's Avatar
I got rid of the older versions. It shouldn't matter anyways since that's the version that's in the system PATH.
Team 4334 2012-2014
Unread 18-01-2014, 19:48
Programmer
It shouldn't, but that doesn't mean it doesn't. What if you try reinstalling it altogether (are you using C++ or Java?)? Or try deleting the other files it makes?
Unread 19-01-2014, 15:13
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Hmm, that is interesting and confusing. Would you mind pasting the sha1sum of sfx.jar, sfxlib.jar and sfxmeta.jar?
Whoa, just testing right now with 7u51 I get a strange error that we only saw on Java 8 but its different to what you have... Would you mind trying with 7u45 if you can?
Watchdog.Kill();
Unread 19-01-2014, 20:00
hiyou102's Avatar
Using my linux machine that has 7u45 (can't get to the Windows computer I've been testing on today) it spits out the following error code:
denis@denis-Aspire-3830TG / $ sudo  java -jar sfx.jar
file:/sfx.jar!/jrubyfx/imports.rb:71:in `const_missing'
file:/sfx.jar!/jrubyfx/controller.rb:334:in `get_fxml_loader'
file:/sfx.jar!/jrubyfx/controller.rb:117:in `load_into'
file:/sfx.jar!/jrubyfx/core_ext/stage.rb:82:in `fxml'
file:/sfx.jar!/jrubyfx/module.rb:49:in `with'
file:/sfx.jar!/jrubyfx/java_fx_impl.rb:119:in `launch_app_after_platform'
org/jruby/gen/InterfaceImpl777276342.gen:13:in `run'
My sha1sum's are:
64fcdf3b0581b7984f9bb46f445d76327b0c4d4e  sfx.jar
1c9eb494fe5b887e13e65a5df6afaee722c15d86  sfxlib.jar
acc23b6c9f2dab9ec9f41085c1112d55e9875b31  sfxmeta.jar
Team 4334 2012-2014
Unread 21-01-2014, 16:46
byteit101's Avatar
Hmm, the latest sums are
f87153004a148ca2e1af6e855ee61ad9e6dedd21 sfx.jar
8af943793e339c5ada2e01714f82ade68d886fc5 sfxlib.jar
ea4181a899de37042f393a5536a143ccc68a510d sfxmeta.jar
could you re-download sfx.zip from here and try again: http://frcbuilder.wpi.edu:8190/job/S...tifact/sfx.zip
Watchdog.Kill();
Unread 25-01-2014, 14:39
mryfrmr's Avatar
mryfrmr mryfrmr is offline
AKA: Mary Farmer
FRC #0191 (XCATS)
mryfrmr is an unknown quantity at this point
Hi, I am getting the same message, and I don't see the sfxlib.jar file in the sfx.zip file downloaded from the above link.
