Go to Post A thread already exists (and boy, does it exist!) on the topic: - Billfred [more]
Unread 14-01-2014, 21:53
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Custom position with pneumatics?
Hi all.
Is there a way to make pneumatic cylinders extend to say ... 1/3 of the stroke length? Right now all I'm able to do with pneumatics is to fully extend or fully retract the cylinders. Is there a way to cutoff the air before the entire cylinder fills up so you have air on both sides (ie. custom length), or is there some other way of doing this that I'm missing?
Thanks.
Unread 14-01-2014, 22:01
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: Custom position with pneumatics?
You can get 3 position cylinders ( http://www.bimba.com/Products-and-Ca...hree-Position/ ).
Edit:: Apparently you can customize where it stops (read the later posts.) You learn something new every day.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 14-01-2014, 22:44
Racer26 Racer26 is offline
There exists three position valves with a center-stop position.
There also exists methods to achieve something similar by valving the exhaust side of the valve feeding your cylinder in a creative fashion.
1075 built an infinitely multiposition pneumatic arm this way in 2007.
Unread 14-01-2014, 22:49
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Not effectively, or reliably, but:
If you filled the retracting side with ~40PSI and capped it shut, and applied 60PSI to the extending side, the cylinder would reach equilibrium at 1/3 extension.
That being said, as Delta P approaches zero, Force approaches zero too, so it would not be very powerful and thus not very useful
Unread 14-01-2014, 23:42
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
We (1247) did this last year with a standard bimba two position cylinder for angling our shooter. Applying full working pressure on both sides simultaneously holds the cylinder at that position. Add magnetic reed switches and viola. We used a 1" cylinder I believe, very hard to move by hand, and worked very well. (only thing did on that bot :/)
"No, you can't use the Kinect to do pelvic thrusts."
Unread 15-01-2014, 00:03
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
Yes, intermediate positioning is definitely possible. We built a fairly successful prototype this summer, although we didn't really have the necessary equipment to do the job right.
The basic idea is that you use a two position valve to control direction, and then use simple open/close valves on each exhaust to control motion. Nothing moves until ONE of the two exhaust valves is opened. Speed can be controlled by modulating air flow in the exhausts. We did not have solenoid operated open/close valves, so we just used manual ones from the hardware store. The system worked fairly well using the two manual valves.
I believe this can all be done using a three position valve. They are pricey so we haven't tried it yet.
Unread 15-01-2014, 00:05
DampRobot's Avatar
Physics Major
AKA: Roger Romani
We've also just tied a string to the end of the piston to limit how far it extends. Of course, you can't make it extend beyond that string somehow, without removing the string.
-Plutarch
Unread 15-01-2014, 00:10
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Another solution, depending on your space constraints could be to put 2 pistons in series and get a "4 position" setup. Say, using a 1 inch and 2 inch stroke piston, you could get 0, 1, 2, and 3 for lengths.
Those of you with any computer background might notice a binary system emerging...
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 15-01-2014, 01:30
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The bimba cylinders are available in stainless steel and a magnetic plunger that can be detected by the reed switches mentioned above. Every order to bimba of mine spec'd the magnetic model but our team has yet to use any. Sorry to say I'm short of real-world experience on how hard it is to detect the transition point. Oh yeah, you get three free, so why not experiment a bit?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
