Go to Post FIRST isn't about building robots. I know. But I also know that Inspiration comes in a lot of flavors and I, for one, believe it is a lot easier to inspire my kids when we set "playing after lunch on Saturday" as a worthy team goal. - Joe Johnson [more]
Unread 14-01-2014, 16:22
cvillerobotics cvillerobotics is offline
FRC #5243
cvillerobotics is an unknown quantity at this point
Spring Coil
Where can I buy a spring coil? My team requires a spring coil that will be able to provide enough torque to propel the 2014 FRC Game piece off a catapult.
Unread 14-01-2014, 16:27
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Spring Coil
Vulcan Springs donated 3 flat force springs of any size to all FRC teams. I would recommend that you start there.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 14-01-2014, 16:29
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: Spring Coil
http://www.mcmaster.com/#compression-springs/=q92d5r
Is this what you are looking for? McMaster is a great place to go looking for raw materials that your local hardware store might not carry. Surgical tubing is also a great way to utilize stored energy.
Unread 15-01-2014, 03:19
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: Spring Coil
https://www.google.com/#q=trampoline+springs&tbm=shop
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 15-01-2014, 08:29
jman4747's Avatar
jman4747 jman4747 is online now
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Spring Coil
We just got two of the 2" wide 40lb constant force springs from McMaster Carr. All I will say is exercise caution and I would recommend starting with the 20lb springs making sure you can mount the 40lb ones later if you need. Also if you use the 40lb springs the two holes are clearance for 1/4-20 bolts and their centers are .625" from each edge.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 16-01-2014, 17:15
FRC #5243
Re: Spring Coil
Do i contact vulcan spring via email? We are a rookie team and not so familiar with these things...
Unread 16-01-2014, 17:36
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Spring Coil
The list of Product Donation Vouchers (PDV) for the various sponsors are here: http://www.usfirst.org/roboticsprogr...c/kit-of-parts
Some may have additional instructions from the kit of parts (KOP) or your lead may need codes from TIMS
