Go to Post GP is asking for something then having twenty people answer graciously. - synth3tk [more]
Unread 14-01-2014, 16:26
ktrobotcreator's Avatar
ktrobotcreator ktrobotcreator is offline
Programmer
FRC #1245 (Shazbots)
ktrobotcreator is an unknown quantity at this point
SFX (SmartDashboard 2.0) with Driver Station
Hi guys!
So I am trying to set up SFX to open on default with Driver Station, and I'm having troubles. I followed the steps on this site (http://wpilib.screenstepslive.com/s/...h-with-the-ds), and I also followed all of their troubleshooting options. SFX opens from both Windows Explorer and Command Prompt, so that's not the problem. The path is also correct. Is anyone else having trouble or success with this?
Thanks!
Katy
FRC Team Shazbots 1245
Project Manager
Head Programmer
Unread 14-01-2014, 16:29
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: SFX (SmartDashboard 2.0) with Driver Station
http://www.chiefdelphi.com/forums/sh...d.php?t=124504
Same as us?
All opinions are my own.
Unread 14-01-2014, 21:54
Programmer
No, we don't have this error. See my reply to that post for more details on that specific error.
For us, SFX opens just fine, just not with Driver Station.
Unread 14-01-2014, 23:44
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Can you post exactly what you have as the command to open the dashboard?
Unread 14-01-2014, 23:57
Programmer
In the FRC DS Data Storage.ini file, this is the line to do that...
DashboardCmdLine = "java -jar C:\\Users\\Shazbots\\sunspotfrcsdk\\tools\\sfx\\sfx.jar"
I have tried a few variations of that line, including single slashes and putting quotes around the C:\\... with both single and double dashes. None of those options work.
Unread 15-01-2014, 00:04
Could you try
DashboardCmdLine = "java -jar "C:\\Users\\Shazbots\\sunspotfrcsdk\\tools\\sfx\\sfx.jar""
Also make sure on the driver station that "default" dashboard is selected
Unread 15-01-2014, 00:06
Programmer
I'm pretty sure I already did, but I will try again tomorrow just to confirm it works or doesn't work. I'm home for the night without that computer so I'll let you know as soon as I can try (probably tomorrow morning).
Unread 15-01-2014, 00:27
I'm also unable to get SFX running from the driver station (but am able to run it from the command line). My command line is
DashboardCmdLine = ""java -jar C:\\Users\\Joe-XPS13-W7\\sunspotfrcsdk\\tools\\sfx\\sfx.jar""
I'm running Windows 7 64 bit with 64 bit java. I just updated java tonight, so I'm running 1.7.0_51
Unread 15-01-2014, 10:44
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
It works correctly on my laptop and I followed the documentation exactly. When I get home I'll post my configuration file.
Unread 15-01-2014, 10:48
Programmer
Originally Posted by nickmcski View Post
Could you try
Didn't work.... The "default" dashboard is selected, and I have tried various things like double clicking it and switching between the other options before going back to it.
I'm also running Windows 7 64. There are three Java updates/JDKs I have installed:
Java 7 Update 45 (64-bit)
Java SE Development Kit 7 Update 45 (64-bit)
Java(TM) 6 Update 24
I know SFX should only run with Java 7, and it will run on my computer.
Unread 15-01-2014, 10:50
Programmer
I guess it's also worth noting that last year we got the first version of SmartDashboard working, so we have been able to successfully edit the settings document so it changes accordingly. I haven't tried that again this year.
Unread 15-01-2014, 11:16
Also make sure you are editing the config file when the driver station is closed other wise it will overwrite it when it closes.
Unread 15-01-2014, 16:09
Programmer
Yep, I have been doing that.
Unread 15-01-2014, 16:16
Programmer
Have you (meaning anyone who has it working) integrated it into your code? The code I have currently doesn't use SmartDashboard, so I'm wondering if maybe you need to be using it for it to come up?
Unread 15-01-2014, 16:37
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
(sfx dev here) Shouldn't be necessary. Do you have multiple JVM's on your system by any chance?
Watchdog.Kill();
