Go to Post A big bowl of popcorn and FIRST. It doesn't get much better than that. - Warren Boudreau [more]
Unread 09-01-2014, 15:05
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Gyro Rate Constant
Although the Labview VI for Gyro setup defaults to 0.0125, it looks to me like the sensitivity for the KOP gyro is actually 0.0072 mv/d/s
Anyone verify this for me?
Phil
Phil Malone
http://www.GEARSinc.org
Unread 09-01-2014, 15:13
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: Gyro Rate Constant
0.007 is what we use.
Edit: The sensor manual currently on the KOP Control System page links to the 2012 documentation.
Unread 09-01-2014, 15:21
Originally Posted by ebmonon36 View Post
0.007 is what we use. It is documented in the sensor manual. They did not update the front cover on it so it still says 2012.
http://www.usfirst.org/sites/default...meter-Gyro.pdf
According the KP Checklist, the gyro is an ADXRS652BBGZ-RL, rather then an ADW22307 as was used in previous years (and what is described in that document).
A quick check of the datasheet makes it look like the sensitivity is configurable. It would be either 0.007 or 0.006.
Originally Posted by PhilBot View Post
0.0072 mv/d/s
I think you mean V/d/s
Unread 15-01-2014, 11:09
Joe Derrick's Avatar
Joe Derrick Joe Derrick is offline
Mentor - Programming
FRC #0319
Joe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of light
I can confirm that the default of 1.25 does not work and something like 0.0072 does work for the 2014 KOP Gyro
