Go to Post it should not matter the gender of a person but rather their ability. - vivek16 [more]
Unread 15-01-2014, 11:41
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Legal Counterweights
If you're using one battery to both power your robot and act as a counterweight, that's allowed.
If you have one battery powering your robot and another as a counterweight, then that's unsafe by definition. One battery is dangerous enough.
Unread 15-01-2014, 11:49
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
It would probably be ruled unsafe by inspectors and disallowed. The batteries are sealed lead acid and have the potential to explode if a cell is damaged or ruptured. One of the easiest ways to rupture a battery is for it to see a hard impact, such as dropping it. By mounting the battery as your counterweight, you are necessarily lifting it up high and putting it through a rapid motion path which could cause it to come loose or collide with something.
Unread 15-01-2014, 11:50
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
For 2005, 857 had a 'tetra cannon' which was counterbalanced by the battery. So, since the rules haven't changed "that" much, so long as it's the only battery, is safe, and can be removed for robot weighing, it should be okay.
Unread 15-01-2014, 12:03
The rule is
R31
The only legal source of electrical energy for the ROBOT during the competition, the ROBOT battery, is one of the following approved 12VDC non-spillable lead acid batteries:
And
R35
The one ROBOT battery, the one main 120-amp (120A) circuit breaker...
Emphasis mine.
One and only one please. As to counter weight for your trebuchet, by definition that would add significant electrical loss through the long #6 or larger wire. If you were to mount the 120 amp circuit breaker on the robot, then a significant length of wire would be unprotected should a short occur. While this is not specifically addressed in the rules, it is bad electrical practice to do so.
Unread 15-01-2014, 13:48
KevinG KevinG is offline
Chesapeake LRI/Friendly Giant
AKA: Kevin
FRC #3650 (RoboRaptors)
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
You'll be spending a lot of time justifying that the design is safe to the inspectors. I would suggest focusing on a different approach.
Unread 15-01-2014, 13:50
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Shifting the battery around to move the CG is one thing. The shock from it being a counter weight for a trebuchet is another. It already gets banged around enough just being on the robot.
