Go to Post Teams that TRY to win and TRY to do their best end up having students that learn more, learn the value of hard work, and are inspired by the process. - Chris Hibner [more]
Unread 15-01-2014, 06:59
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
Powering Arduino
How would you power an arduino? I know its considered a custom circuit but do you power it. With a small fuse directly from the PD board, or can you tie it in with the 12v-5v- voltage converter? R43 says nothing else can be connected to the PD where the converter gets its power but they dont specify the low volt side of the converter. Any help is appreciated.
Unread 15-01-2014, 08:00
Re: Powering Arduino
Under the current rules, you can feed a custom circuit through a small breaker on the PD under R46 with a smaller fuse on the custom circuit. You may not use the power supplies on the PD for anything other than the cRio, radio and camera. A small three terminal regulator and a few components on a small, insulated, custom circuit is an appropriate method of supplying 5 volts to another custom circuit.
Unread 15-01-2014, 08:11
yash101 yash101 is offline
AKA: null
Wait a minute, so you can't power a computer off the PDB regulators? (The 5v rail)
Unread 15-01-2014, 08:49
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
For a low power device like an Arduino, you can also power it from the 5v on the digital sidecar (Digital I/O PWR).
Unread 15-01-2014, 08:52
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Just power it directly from the PD. The arduino can take in 12v, just make sure you know that anything powered from the 'Vin' pin on the arduino is also going to be 12v and will fry whatever 5v electronics you hook up to it
Unread 15-01-2014, 09:57
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We used 6v from the servo power supply through Arduino's vin.
You can use the PD board 5v supply if you would like:
R36
All circuits, with the exceptions of those listed in R42 and R45, must connect to, and have power sourced solely by, a single protected 12VDC WAGO connector pair (i.e. the Load Terminals, as shown in Figure 4-11) or the 5VDC supply on the PD Board (as shown in Figure 4-12), not the M6 shanks.
You can't use the cRio or radio supply though.
Kettering Motorsports
Unread 15-01-2014, 10:04
There are no restrictions on the pdb 5v supply (the "camera" supply ). In fact, its explicitly allowed for other uses by R36.
Unread 15-01-2014, 10:17
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
We went with a 5v 3A regulator from CPT last year to power our Arduino and connected LED light strips.
This is the same company that makes the regulator for the wireless bridge.
http://www.current-logic.com/dcdc_co...cpt_fulree.php
  • It's potted so no worries about shorts due to debris
  • Screw terminals for easy mounting
  • Cheap: You can find them on ebay for a few bucks
We didn't have any problems with it on/off season. This would certainly be overkill if all you needed to run was an arduino. If you need to drive other components as well off the supply though, it's a great option.
http://team2168.org
Unread 15-01-2014, 10:43
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
steinra is on a distinguished road
This is right along the same topic we were working on last night.
I know that the rules have specific restrictions for motor power and other devices having their own connect points to the PD.
What was not clear is a custom sensor circuit, multiple loads.
We want to accomplish the same thing the PD is doing for the cRIO. A DC to DC step up to 24v, 5A, bring back down to 5v, 5A to power the other systems. (LED strips need a lot of power as do several computing devices). May also need to pull 12V off the 24V step up.
This branch circuit would have LED lights, Arduino and let's say a Raspberry Pi or two, plus and USB devices hanging off them.
What is not clear to me is if each of those would require their own power, or can all of those be supplied by the same 5v supply off a single breaker / fuse on the PD?
I may need to frame it up as a GDC question, but want to make sure it is phrased in a way that we don't get the "can't speak to specific designs" answer.
Ultimately I am trying to figure out if I need multiple separate 24V step ups with their corresponding step downs for each device, or can I have a "sub" PD with separate fusing?
Thanks!
Randy
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
Unread 15-01-2014, 10:59
amesmich's Avatar
FRC #4638 (Jagbots)
Thanks for the replies. I think we may go with the "otherguy"s route. I dont want to start messing with the PD 5v supply and get called. I would rather branch out with my own circuit. Clean and confined.
Unread 15-01-2014, 11:55
Randy,
Why are you going up to 24 volts to step back down to 12 or 5 volts?
Unread 15-01-2014, 12:08
Volunteer, WPILib Contributor
no team (Waiting for 2021)
There are actually 3 places you can get a stable 5V supply off the robot. You can grab it off the PD, off the Sidecar, and off the Analog Breakout. I don't have the schematics in front of me right now, but I believe the Analog Breakout can source about 1A, which is defiantly enough to power an Arduino. Because most analog circuits won't source much, you should have alot of that power free.
Team 4488 - Mentor 2013-2016
Unread 15-01-2014, 12:14
steinra's Avatar
(KG7KEO)
AKA: Randy Steiner
Thank you for the question Al!
It is more for the 12v than the 5v, but to allow for the voltage drops in the battery supply side under heavy drive load (see supply drops to 9v/10v during heavy acceleration / motor use). Mainly to avoid brown out conditions for devices that need that stable higher voltage.
My understand as well for why they are stepping up the voltage in the PD for the devices connected there (cRIO, radio, camera). Voltage rail stability. I could be understanding incorrectly as well. (in looking at the schematic, this may be the case of me being off)
Now I see in the PD schematic that there is both a 24v, 12v step up and a 5v buck switching. The corresponding devices i think would step down to 5v and 3.3v.
Now it could be the cRIO only came in 24v, so that could be the reason as well, but would expect the step up would help with supply side stability.
Rethinking (or as the GPS says, recalculating). For the 5v supply I might be able to get away with the buck now that I think about it some more, and may be able to get away with the 12v step up only.
I really appreciate the question as it made me think more about it. Maybe we will just build these like the PD has and do multiple supplies (now to find the best way to SMD )
I am not a EE, so may be WAY off here.
Thanks!
Randy
Randy Steiner
Unread 15-01-2014, 12:20
otherguy's Avatar
sparkE
AKA: James
Consider all your separate custom circuits as one system, a black box. Power goes in, it does some stuff.
You can consider them multiple separate custom circuits, or as one single custom circuit.
That said, why are you stepping up to 24v then down to 12v and 5v?
It doesn't sound like you need 24v at all in your custom circuit. It sounds like 5v and "possibly" 12v.
You can get 12v directly off the PDB through a breaker. No rule violation there.
You can get 5V for a custom circuit from any of the places listed above in this thread.
If you have LED strips. Get a 12v to 5v regulator with a high enough current rating to feed your strip, and plug it in to the PDB...
Don't make it harder than it has to be.
http://team2168.org
Unread 15-01-2014, 12:24
amesmich's Avatar
FRC #4638 (Jagbots)
I have used these in many other projects to regulate 24vdc down to 12v for an arduino (among other things) and they work great. Yes you can give the arduino 24v and it will be ok but I dont like to stress the VR on the arduino that much.
http://www.amazon.com/RioRand-LM2596...c+power+module
