Go to Post I've determined that the only thing rumors are good for is putting your knickers in a twist. - JaneYoung [more]
Unread 06-01-2014, 13:08
Wazzaps Wazzaps is offline
FRC #1573
Wazzaps is an unknown quantity at this point
Question Goalie zone confusion
We are trying to understand if we can score a goal by going to the target goal and extending an arm that will directly push the ball inside the goal. Can we enter the opponent's goalie zone and extend ourselves. Thank you.
Unread 06-01-2014, 13:10
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Re: Goalie zone confusion
G22
If a ROBOT is not in contact with the carpet in its GOALIE ZONE, its height (as defined in relation to the FIELD) must not exceed 5 ft.
Violation: FOUL. If continuous or repeated violations, TECHNICAL FOUL.
No, a robot can only extend beyond 5 ft. if within its own goalie zone.
Unread 06-01-2014, 13:14
FRC #1573
But what goalie zone is the "own" goalie zone?
and won't the 5ft and the ball height would be enough to just get to the other goalie zone and score?
Unread 06-01-2014, 13:17
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
The blue alliances goalie zone is in front of the red goals. You can extend up to infinity (within a 6 in cylinder) in this zone, however when you enter the opponents goalie zone (in front of your goals) you cannot exceed 5 ft.
Unread 06-01-2014, 13:18
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Per the glossary, your goalie zone is defined as the one marked by tape between your opponent's front edge of their low goal and your alliance's alliance wall.
Originally Posted by Glossary
GOALIE ZONE: the area in front of an ALLIANCE’S ALLIANCE WALL, bounded by the opponent’s LOW
GOALS and black tape.
If I understand your intention correctly, are you trying to score in the low goal? If yes, there have not been any rules that prohibit extending a mechanism into the goals, provided you are within all the other rules. The one to look out for would be R3, in which all extensions have to be within 20" of frame
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 06-01-2014, 13:19
Brandon Ha Brandon Ha is offline
FRC #0302 (Dragons)
Team Role: Electrical
Brandon Ha is on a distinguished road
The Goalie Zones are only on the opposing alliances scoring side.
GOALIE ZONE: the area in front of an ALLIANCE’S ALLIANCE WALL, bounded by the opponent’s LOW GOALS and black tape
We all make mistakes.
I make one everyday.
The important thing is.
( \_/ )
(^_^)
Unread 06-01-2014, 13:24
FRC #1573
our plans were basically for you don't understand:
try and reach the other team's goal, extend up to 5ft (according to you guys)
and just sink the ball inside but as the math shows you can't reach that high... any suggestions on how to give a push?
Unread 06-01-2014, 13:35
Qcom's Avatar
Qcom Qcom is offline
Gearhead
AKA: Quentin
FRC #2996 (Cougars Gone Wired)
Qcom is on a distinguished road
I think it is safe to assume that the rules have been designed to require the ball to become airborne for some arbitrary distance in order to be scored in the high goal. Personally, I like the idea of a high arc with little forward velocity; just park right below the high goal next to a low goal cube and lob the ball in.
"The systems... They DON'T INTEGRATE!"
Unread 06-01-2014, 20:18
GaryVoshol's Avatar
Cogito ergo arbitro
2.2.3:
The HIGH GOALS are 11 ft. 6 in. wide and 3ft. 1 in. tall with the bottom edge of the opening located 6 ft. 10 ¾ in. above the carpet
The top of the ball is going to be no more than 1.25 inches above the bottom edge of the opening. I doubt you'd be able to just roll it in.
(since 2004)
Unread 11-01-2014, 14:47
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
If you do not us a piston you will no make it to the high goal. But if you do not want to make the ball air-born you can rely on the assist points and the low goal.
Unread 15-01-2014, 12:19
Jmulderig Jmulderig is offline
FRC #3460
Jmulderig is an unknown quantity at this point
Please clarify:
Can the blue drive into the red goalie zone?
If not can they extend into it (within the 60in ceiling)
Unread 15-01-2014, 13:40
Gearheads1 Gearheads1 is online now
AKA: Brian Holmgren
FRC #4455 (The Burger Bots)
Gearheads1 is an unknown quantity at this point
Blue can drive into the red goalie zone, but their robot can not exceed 60 inches in height in the red goal zone, only in the blue goalie zone, and only one team robot at a time.
Unread 16-01-2014, 09:26
Wzup4021 Wzup4021 is offline
FRC #4021 (igKnightion)
Wzup4021 is an unknown quantity at this point
I'm sorry if somebody has already pointed this out, but here is a snippet from the rules:
G26-1
ROBOTS may not break the planes of the openings of the opponent’s LOW GOALS.
Unread 16-01-2014, 09:28
Something our team is doing is using a piston to "punch" the ball up and through the goal, however we are shooting from much closer to the ground. But that doesn't mean that you couldn't use it higher up like you are saying, and that extra little push could easily send the ball through the goal.
Unread 16-01-2014, 18:52
GaryVoshol's Avatar
Cogito ergo arbitro
G26-1
At the time Caltran posted, G26-1 had not yet been added to the Rules by the GDC.
(since 2004)
