Go to Post Yippee! Someone else that can have their every word over-analyzed, mis-read, inverted, converted, perverted, misinterpreted, reverted, and garbled besides just me! - dlavery [more]
Unread 11-01-2014, 11:22
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
[Ri3D] BOOM DONE. New video w/ more robot shots
While we followed a more instructional format on our initial reveal video (a.k.a. me yammering on about the robot), on this we one show many more shots of the robot doing things -- note we have a self catch in there somewhere.
Hope you like it.
ALSO, go vote for Team BOOM DONE. we are currently behind in the voting, which, while I like the other Ri3D robots, I feel pretty strongly that BOOM DONE. should be winning this vote.
Dr. Joe
Team #88, TJ2
Unread 11-01-2014, 11:32
Re: [Ri3D] BOOM DONE. New video w/ more robot shots
Originally Posted by Joe Johnson View Post
[While we followed a more instructional format on our initial reveal video (a.k.a. me yammering on about the robot)
Don't apologize. That was actually the most helpful and informative of the 4 Ri3D reveal videos.
Do you have any further news to share about the problem you reported earlier with the wheels?
Unread 11-01-2014, 13:30
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Love the videos! It's a toss up between you and O-RYON really, but I hope you win. This is an amazing bot!
When running with El Torro, how hard do you find it to pick up balls? Do you have to be relatively square to get a good grip?
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 11-01-2014, 20:09
raptaconehs raptaconehs is offline
FRC #3200
raptaconehs will become famous soon enoughraptaconehs will become famous soon enough
So in the beginning of the video you show a short shot. Could you show some scores from the farthest of your range? Because our team is really interested in this idea and are currently prototyping it. We would love to see the range of your shooter.
Unread 11-01-2014, 20:17
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Dr. Joe,
I was wondering if slowing down was necessary for your robot to pickup the ball. I'd be interested in seeing what happens when you hit the ball while traveling at higher speeds with the intake running. I loved your design, very compact and well done. I also think the clock on the robot was genius as drivers can't afford to look away from the robot.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 12-01-2014, 11:39
AKA: Dr. Joe
FRC #0088 (TJ2)
The spinning horns center the ball. Pretty much all you have to do is get the ball to touch a stick and it is going up.
Dr Joe
Team #88, TJ2
Unread 12-01-2014, 11:51
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Jay O'Donnell View Post
Dr. Joe,
As it stands, we can hit from 2.4m from the wall. I think with tweaks to the code we could get a bit further away but not too much.
There are mechanical tweeks that can help as well. The green cords (that I love so much) did not seem tight enough. I suppose that tighter bands or more of them (it was rigged for two per motor but we never got to it) will help get more velocity to the ball and improve our range.
In addition, we currently have a 2:1 stage in cord and a 7.5:1 in chain. I think there is optimization to do on the 2:1 stage. Maybe a 3:1 is better, or maybe a 1.5:1?
Now that we have code control, I would like to think about using chain on the first stage (limiting impact loads at the end by controlled decel of the arm). Again, I LOVE that green cord and more folks should consider using it but I love capable robots more. The main reason we used cord was to protect the chain from snapping during impact loading at the end of travel. If we can avoid this problem using software and the robot has a vastly improved range, then. my love for green cord not withstanding, I'm voting for chain.
FINALLY, if 2 (340W each) CIMs are good, won't adding 2 (270W each) Banebot 775s be better still?
That is the beauty of finishing early. Time to experiment and to improve.
Dr. Joe
Team #88, TJ2
Unread 12-01-2014, 12:03
AKA: Dr. Joe
FRC #0088 (TJ2)
Dr. Joe,
Time is definitely on my mind. El Toro is reliable and (imho) robust but it is not the fastest way to pick up a ball.
Current configuration has a 20:1 ratio from Banebot 775 motor to the horn. I think that perhaps a lower ratio (i.e. faster spinning) would make El Toro better.
As to pushing the ball away, the angle of the horns did a pretty good job of trapping the ball. Again, El Toro is not the perfect ball pick up but it is pretty good.
Dr. Joe.
P.S. Display on the robot, I really hope that a bunch of teams implement these. It is SO useful. I expect a lot of creative uses to come from the teams this year and in coming years.
Team #88, TJ2
Unread 12-01-2014, 12:33
FRC #3200
Dr. Joe.
Our team is working on prototyping the El Toro. What height is it off the ground, and what angle is it mounted at with respect to the ground? And when you start a match those horns must be within the frame perimeter so how do you cause the horns to drop down?
Unread 12-01-2014, 13:06
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Thanks for releasing the CAD, code, BoM and more details of the design.
I was pleasantly surprised how inexpensive the display was - about $40 in parts + $25 Arduino.
(Last season one of our students implemented a 2 digit 7 segment display using addressable full color LED strip with the Arduino controller. We also had colored bar chart lights indicating wheel speeds and other telemetry. Our robot design didn't allow us to make full use of the feature but we were very happy with the use of visual feedback on the robot.)
I'd love to see the robot play in match conditions. Perhaps a lunchtime demonstration can be arranged at one of the NE District events?
And a special thanks to whoever added the cost of the 1s and 0s to the software BoM !
Unread 12-01-2014, 20:42
AKA: Dr. Joe
FRC #0088 (TJ2)
Check the CAD but in rough numbers the pivot is about 1-1.5" behind the front of the robot and 0.5-0.75" below the top of the bumper (which is 7" from the ground).
They are not powered and we use acceleration to get the to fall (unless a ball is in the machine in which case we use the motors to "climb off" the ball). If I had to do it again, I would power this joint. I would drive it through a spring so that "down" would only bias the horns toward down and "up" would only bias them toward up. My reason for this is that we could cradle a ball as we drove so that it would be less likely to fall out during a battle for position. Also, we would have another (maybe better) way to remove a ball from the shooter and put it on the ground for another team to pick up.
I like this idea enough that i may do it just as a side project. Time will tell...
Dr. Joe
Team #88, TJ2
Unread 15-01-2014, 14:09
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Did you try grabbing the ball while moving? If you did was it hard?
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 15-01-2014, 14:25
Division by Pirates
This was (sort of) answered already. Read post #8 in the thread.
Unread 16-01-2014, 10:30
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Joe, thanks for doing such a fantastic job with your team! The robot is really impressive. We will be stealing some of your ideas.
Specifically, my team's programmers want to implement the heads-up display for distance. When they tried to access the link for the code, it comes up as broken. Can you repost or update the link? They would love to be able to see what you did.
Thanks again!
Unread 16-01-2014, 11:44
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Thanks again!
We too are looking for the code they used.
That said, we do have working Arduino code that uses an Addressable RGB LED strip to display relative distance. I am more than willing to share this code if anyone would like it. Modifying this code for your requirements is quite simple.
