Go to Post Come on, Dave! We need more lyrics! (I'll bring you fresh KK doughnuts at VCU's regional! :D ) - Squirrelrock [more]
View Poll Results: Do polls make you more interested in reading a thread?
Yes 3 23.08%
No 6 46.15%
These things came with threads? 2 15.38%
I just like voting :-) 2 15.38%
Voters: 13. You may not vote on this poll
Unread 15-01-2014, 14:37
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
What gyro and/or accelerometer do you use?
I'm interested to hear what people's experiences are with various gyro and accelerometers. Do you stick with the KOP ones, or do you have one you've been using for a while? Any fancy tricks or advice as to getting it to work nicely?
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 16-01-2014, 02:11
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: What gyro and/or accelerometer do you use?
In the past, we have used the KOP one, and we have had trouble with it climbing. (It got pretty bad in some matches last year, climbing at a rate of over 1 rps). This year, we are using an arduino based one, the name escapes me.
A "fancy trick" we are doing this year is using vision to do a check on the gyro. The vision returns x y and z displacement as well as pitch roll and yaw. The yaw in vision is the same as the gyro reading that we care about, so every 2 seconds or so, we will set the gyro reading to what vision says it actually is.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 16-01-2014, 21:44
We have used the KOP gyro for the last several years without issue.
The main trick is to make sure the robot is stable during calibration and then reset the angle at the very beginning of autonomous. It will drift, but this minimizes the drift and has never caused us a problem during autonomous.
Unread 22-01-2014, 12:00
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
We are switching to a 9axis IMU called GY-85 available on ebay for $16 including shipping. It uses an I2C interface for accel, gyro and compass. We use the compass as the field orientation instead of integrating the gyro. Works well as long as the sensor is >20" above the motors.
