Go to Post For me, FIRST is inspiration with a positive feedback loop - it just keeps getting better. I wonder where it will go from here... - petek [more]
Unread 15-01-2014, 14:44
garrettshost garrettshost is offline
FRC #5028
garrettshost is an unknown quantity at this point
Arm above 60in
If we have an arm that will extend above 60 inches, will the claw on the end of the arm have to be within the 6 inch cylinder requirement throughout the entire game including in the open position?
Unread 15-01-2014, 14:47
RamZ's Avatar
RamZ RamZ is offline
Project Manager & Driver
AKA: Ram Zallan
FRC #0004 (Team 4 ELEMENT)
RamZ will become famous soon enoughRamZ will become famous soon enough
Re: Arm
Yes.
G23
If a ROBOT is in contact with carpet in its GOALIE ZONE, and for only one ROBOT per ALLIANCE at a time, there is no height restriction; however, any extension or combination of extensions above 5 ft. may not extend beyond a vertical cylinder with a 6 in. diameter (see examples in Figure 3-5).
Violation: FOUL. If continuous or repeated violations, TECHNICAL FOUL.
Team 4 ELEMENT
team4element.com facebook twitter instagram
Unread 15-01-2014, 14:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Arm
First, extending above 60" is only legal in your goalie zone. Just so we're clear that you can't do that all over the field.
Second, yes. Everything that extends above 60" must ALWAYS fit inside a 60" vertical cylinder.
Unread 15-01-2014, 15:21
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: Arm
I may be reading your question wrong but while the appendage is down below 60" it does not have to be within a 6" diameter vertical cylinder as it is not affected by G23 while below the maximum robot height outside of the goalie zone.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 15-01-2014, 15:45
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: Arm
One thing to keep in mind is that "your" goalie zone (the one where you are allowed to extend above the 60" height) is on the side of your opponents' scoring zone. From your original post it sounded like you were thinking of using a claw to "dunk" the ball in your goal which would not be OK. If I misinterpreted your intent there, please ignore this.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
