Go to Post If you aren't sure, Q&A. Now. - EricH [more]
Unread 15-01-2014, 16:49
Mr. 1033's Avatar
Mr. 1033 Mr. 1033 is offline
AKA: Paul E. Lathrop
FRC #1033 (Team CLUTCH)
Mr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the rough
Creating pneumatic launchers
My team is in the process of rapid prototyping a launcher using 2-4 cylinders with 1.5in bore and a 10in stroke to launch the ball.
We have done our hw on here and youtube to see that the concept should work.
We are having a rough time getting the "burst" needed to propel the ball.
Any tips out the as far as how to legally set a system up?
Unread 15-01-2014, 17:11
Richard.Varone's Avatar
Richard.Varone Richard.Varone is online now
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
Re: Creating pneumatic launchers
Take a look at http://www.chiefdelphi.com/forums/sh...hreadid=124312, it may give you some ideas
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
Unread 15-01-2014, 17:14
AustinShalit's Avatar
AustinShalit AustinShalit is online now
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Anytime you use a large bore the speed is going to decrease. You might want to try using a smaller bore.
In order to have an equal amount of force, use multiple cylinders with smaller bore rather than a single large bore for greater speed.
Unread 15-01-2014, 17:57
With motors, you trade speed for torque by using a gearbox.
With cylinders, you trade force for speed by using levers.
Unread 15-01-2014, 18:08
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Perfect example.
1 1 1/2" dia. cylinder with 60psi of air pressure applied produces 106Lb of force.
2 1 1/6" dia. cylinders with 60psi of air pressure applied produces 106Lb of force.
Unread 15-01-2014, 18:40
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
We have a successful prototype using two two-inch diameter, three inch stroke cylinders on a lever catapult. The cylinders are attached three inches from the catapult lever pivot, and the ball is placed 20 inches from the pivot. The catapult moves from horizontal through 45 degrees. We have a reservoir downstream from the 60 psi regulator and a reservoir upstream from the regulator at 120 psi. Each cylinder has its own solenoid. The tension side of the cylinder is open. The ball goes into the high goal reliably.
Unread 15-01-2014, 18:42
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Originally Posted by billbo911 View Post
Perfect example.
Note that with the same stroke length, it takes the same volume of gas to fill both of these configurations. With only a single solenoid valve supplying the gas, they fill in exactly the same time. The thing that allows the second configuration to fill faster in a FIRST robot is the ability to use two valves to fill the same volume.
In the real world, using a single large cylinder and filling with two valves would be more weight efficient than the second configuration mentioned. I hate seeing people tossing around generalities like "larger cylinders are slower" without stating the underlying assumptions behind the specific application that makes it so. I fear we're teaching our students design "rules" which are only true in the restricted world of FIRST robotics, but are completely reversed in the real world.
Another approach would be to use the single cylinder from configuration 1, and use a faster flowing valve, a perfectly valid option this year. People are finding legal valves with more than twice the flow capacity than previously legal valves.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 15-01-2014, 21:13
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
we are using (2) 1 1/2 bore 10 inch stroke and we seem to have no problem https://www.youtube.com/watch?v=fljCPwHhnHw
Faridodin "Fredi" Lajvardi KD7WKD
Unread 16-01-2014, 01:33
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rick,
when I first heard what you folks were doing, I was very skeptical it would have enough force (speed).
But as Ether has pointed out, the lever arm is the key.
I saw a video clip of the prototype.....nice work.
Unread 16-01-2014, 01:36
Oblarg Oblarg is offline
AKA: Eli Barnett
I would recommend checking out the geometry of the shooter posted by MrForbes in an earlier one of these threads. It's a very clever design that is very forgiving re: airflow into the cylinders (though you absolutely must remove the fittings to maximize airflow *out* of the cylinders).
"The breakfast of champions!"
Unread 16-01-2014, 01:53
billbo911's Avatar
As long as you are taking my comments out of context, then you are right. That said, I was only giving an example of equal force provided with two commonly available cylinders.
In FIRST, access to a large variety of parts is a given. Although, many teams are on restricted budgets and thus can not afford to by valves just to attain a higher flow rate. These teams need to be creative with what they do have access to.
There are ways to actually exceed the flow rate that is available from even the highest flow valves that are legal within the rules this year.
Unread 16-01-2014, 07:56
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Sorry, Mr. Bill. I wasn't calling you out at all. Your example was right on the money. I was reacting to this post.
Anytime you use a large bore the speed is going to decrease. ...
This design advise is correct in the context of FIRST robotics, assuming both cylinders are fed by valves with the max allowable Cv. But, it's not what you would normally do in industry.
At this stage of the design process, the students are coming up with a lot of different ideas for how to execute different concepts. Some of those are great ideas in the "real world", but not in a FIRST robot, because of the restrictions imposed by the rules. Some of those ideas are great for a FIRST robot, but are not what you would do in industry. I always take great pains to explain the difference because I don't want a student to internalize a "lesson learned" from the world of FIRST robotics and apply it to real world engineering when it might only be true in the context of the FIRST robot rules.
Whether it's because of imprecise language or because they have learned the wrong lessons, you see a lot of half-true design rules quoted by students (and occasionally mentors) on CD. I think as mentors we're responsible to explain to the students how these design rules are context dependent, and how the underlying assumptions affect their design decisions.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 16-01-2014, 10:33
billbo911's Avatar
... Whether it's because of imprecise language or because they have learned the wrong lessons, you see a lot of half-true design rules quoted by students (and occasionally mentors) on CD. I think as mentors we're responsible to explain to the students how these design rules are context dependent, and how the underlying assumptions affect their design decisions.
Spot on Todd!
There are MANY variables that have to be taken into account when designing a system, and this applies to almost any "system".
The language we use to communicate those ideas has to be correct, and should be thorough. Leaving out small details can lead to misunderstandings, as can been seen in this thread.
In this vein, here is what we will be doing in the next couple weeks.
We have a prototype we are satisfied with. It will be put into CAD, and then built accordingly.
Once built, we will run a couple thought experiments (Hypothesis), run several tests (Experimentation) , and then formation of our conclusions.
The goal of this is to optimize our catapult for competition based on the actual design we are using.
