Go to Post "Mother nature does not give partial credit" -Woodie Flowers, Kickoff 2003 - TerryDolan [more]
Unread 15-01-2014, 18:42
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: Creating pneumatic launchers
Originally Posted by billbo911 View Post
Perfect example.
1 1 1/2" dia. cylinder with 60psi of air pressure applied produces 106Lb of force.
2 1 1/6" dia. cylinders with 60psi of air pressure applied produces 106Lb of force.
Note that with the same stroke length, it takes the same volume of gas to fill both of these configurations. With only a single solenoid valve supplying the gas, they fill in exactly the same time. The thing that allows the second configuration to fill faster in a FIRST robot is the ability to use two valves to fill the same volume.
In the real world, using a single large cylinder and filling with two valves would be more weight efficient than the second configuration mentioned. I hate seeing people tossing around generalities like "larger cylinders are slower" without stating the underlying assumptions behind the specific application that makes it so. I fear we're teaching our students design "rules" which are only true in the restricted world of FIRST robotics, but are completely reversed in the real world.
Another approach would be to use the single cylinder from configuration 1, and use a faster flowing valve, a perfectly valid option this year. People are finding legal valves with more than twice the flow capacity than previously legal valves.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 15-01-2014, 21:13
falconmaster's Avatar
Happy Birthday! falconmaster falconmaster is online now
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
we are using (2) 1 1/2 bore 10 inch stroke and we seem to have no problem https://www.youtube.com/watch?v=fljCPwHhnHw
Faridodin "Fredi" Lajvardi KD7WKD
Unread 16-01-2014, 01:53
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
As long as you are taking my comments out of context, then you are right. That said, I was only giving an example of equal force provided with two commonly available cylinders.
In FIRST, access to a large variety of parts is a given. Although, many teams are on restricted budgets and thus can not afford to by valves just to attain a higher flow rate. These teams need to be creative with what they do have access to.
There are ways to actually exceed the flow rate that is available from even the highest flow valves that are legal within the rules this year.
