Go to Post Everyone has regrets in robotics- it's how you learn from them that makes all the difference. - Kevin Leonard [more]
Unread 15-02-2013, 01:51
tac tac is offline
FRC #4765
tac is an unknown quantity at this point
CANNotInitializedException
We've been trying to get our CANJaguar code working, but it keeps returning the CANNotInitializedException.
Our code right now is
public void robotInit(){
     try {
          CANJaguar armMotor = new CANJaguar (4,       CANJaguar.ControlMode.kPosition);
     } catch (CANTimeoutException ex){
          ex.printStackTrace();
What the console says:
[Squawk VM] Version: 2011 FRC, Nov  5 2011, 14:34:13
[cRIO] FPGA Hardware GUID: 0x1394f6dc1feb42ec6910e5767ed1d22c
[cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] DIO LoopTiming: 260, expecting: 261
[cRIO] edu.wpi.first.wpilibj.can.CANNotInitializedException
[cRIO]     at edu.wpi.first.wpilibj.can.CANExceptionFactory.checkStatus(CANExceptionFactory.java:44)
[cRIO]     at edu.wpi.first.wpilibj.can.JaguarCANDriver.sendMessage(JaguarCANDriver.java:36)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.sendMessage(CANJaguar.java:574)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.getTransaction(CANJaguar.java:637)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.getFirmwareVersion(CANJaguar.java:1199)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.initCANJaguar(CANJaguar.java:247)
[cRIO]     at edu.wpi.first.wpilibj.CANJaguar.<init>(CANJaguar.java:286)
[cRIO]     at edu.wpi.first.wpilibj.templates.RobotTemplate.robotInit(RobotTemplate.java:70)
[cRIO]     at edu.wpi.first.wpilibj.SimpleRobot.startCompetition(SimpleRobot.java:104)
[cRIO]     at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase.java:156)
[cRIO]     in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO]     at javax.microedition.midlet.MIDletTunnelImpl.callStartApp(64)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1506)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
[cRIO] WARNING: Robots don't quit!
[cRIO] ---> The startCompetition() method (or methods called by it) should have handled the exception above.
[cRIO] task 0x25c7bb8 (System Web Services Load Thread) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x28784f8 (mDNS resolve) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x2bff230 (mDNS resolve) deleted: errno=0 (0) status=0 (0)
We'd love your help. Thanks!
Unread 16-02-2013, 22:49
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
Re: CANNotInitializedException
Also, you cannot define a jaguar inside of a code block (in this case, your "try" block, and then use it anywhere outside of the block. Outside of any method, but inside your class, type (you may have already done this):
CANJaguar armMotor;
Then, change your code that you displayed to this:
(Basically remove the CANJaguar variable marker):
     try {
Essentially, what is happening is that you're not initializing your global CANJaguar variable. How Java works is that it allows global and local variables of the same name. So the Jaguar that you're initializing isn't the same one that you're using at line 70. You made a new Jaguar also called "armMotor" and initialized that one. Because it had a conflicting name, Java resolved this by "hiding" the global variable from that function. The armMotor inside robotInit() was discarded after robotInit ended. The other armMotor that you defined elsewhere was never touched. By removing the CANJaguar reference, you're not creating a new variable anymore but instead initializing the existing global one, which is what you intended on doing.
Unread 13-01-2014, 21:46
Metis Metis is offline
FRC #4203
Metis is an unknown quantity at this point
The described error will occur if the cRIO has not had a CAN plugin set when the firmware was flashed. You need to re-image the cRIO to solve the problem.
Unread 15-01-2014, 21:06
Ipiano's Avatar
Ipiano Ipiano is offline
AKA: Andrew Stelter
FRC #3018 (Nordic Storm)
Ipiano is an unknown quantity at this point
AriTheHun, I believe you would be correct if the issue were a CANTimeoutException, but this is a CANNotInitializedException, which, as Metis said, is supposed to occur when the CAN Driver is not properly loaded.
________
Genius is one percent inspiration and ninety-nine percent perspiration.
--Thomas A. Edison
Unread 16-01-2014, 07:51
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
CANJaguar armMotor;
     try {
This would actually cause a compilation error, not a runtime error as the jaguar object would be out of scope when you tried to use it.
Unread 16-01-2014, 15:13
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
So does it work if you select a CAN driver in the imaging tool?
