Go to Post there is no such thing as too many parts or useless parts, only parts you dont need yet. - Cuog [more]
Unread 10-01-2014, 12:09
jzeiders jzeiders is offline
AKA: Jack Zeiders
FRC #4096 (Ctrl-Z)
jzeiders is an unknown quantity at this point
Solenoid Legality
We are wishing to use this solenoid (0.67 CV):
http://www.stcvalve.com/Solenoid_Val...ions-4V100.htm
It as a 1/8 npt so it should be legal, but are there any other things that would make it against the rules.
Also if anyone as found a better solenoid it would be awesome if they would share it.
Unread 10-01-2014, 15:44
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Solenoid Legality
The only restrictions are port size and price, neither of which are broken by this. If the manual doesn't say that something is restricted or banned, then it isn't.
Unread 16-01-2014, 13:44
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
What rule number says price constraint?? I found some Parker solenoids that are 12volt, and 1/8" pipe. I assume they are legal, but am having an issue finding any other rule specs.
Unread 16-01-2014, 13:52
R11
Unread 16-01-2014, 13:59
dradel's Avatar
Thanks for the input. I was looking high and low in the pneumatics section and found nothing.
So as long as it is less than $400 and has 1/8" pipe thread, and 125psi rated its legal?
Unread 17-01-2014, 13:35
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Technically, the solenoid valves don't have to be rated for 125 psi if you use a second safety relief valve set lower than the solenoid's rated pressure. But yes, those are the only requirements this year.
