Go to Post All the "official game hint" is is an "official red herring" - Cory [more]
Unread 16-01-2014, 12:44
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Ball "Scuffs" and G10
I intend to ask Q&A about scuff marks. I am concerned that the blue box definition ("routinely mark") will make some shooter designs a problem, even if they don't risk popping or ripping the balls. Anyone seen a definitive answer for this yet? Any thoughts as to what might be said, realizing it's just opinion?
Unread 16-01-2014, 12:51
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Re: Ball "Scuffs" and G10
Did you see the answer posted in the Q&A about this?
Game - The Game » Game Rules
Q114 Q. Rule G10 prohibits team from routinely "marking" the game pieces. Would contacting the ball with spinning wheels leaving a small streak of rubber on the ball be considered a violation of this rule, even if there is no permanent damage to the game piece or tear to the fabric?
A. Per the Blue Box on G10, occasional marking of the BALL is not a violation of G10, but routine marking of the BALL is.
Unread 16-01-2014, 12:53
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
It's already been asked about on Q&A and the answer won't get more detailed than that.
This has been in the rule book the last three seasons(at least) and is always asked about in Q&A and is always the same. I've never seen a team get a penalty for marking a frisbee/gamepiece. I think the intent of the rule is to make sure all balls are always functional. Ie. 2013, teams that (occasionally and unintentionally) shredded frisbees slightly where okay, teams 2012 plenty of balls ended up marked with black streaks, and it was rarely an issue (in regards to penalites and such)
Unread 16-01-2014, 13:14
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
This isn't something the GDC can answer on the Q&A because it is very situational and is up to the refs to decide.
If they are large black marks and you make them every time you shoot a ball, you are probably going to get called on it. If they are small inconspicuous marks or they only happen every now and then, the refs will likely let it slide.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 16-01-2014, 13:19
KevinG KevinG is offline
Chesapeake LRI/Friendly Giant
AKA: Kevin
FRC #3650 (RoboRaptors)
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
One of the designs we considered used rotating wheels to fire the ball out at fast speed. A single shot was enough to leave a pair of black streaks along the ball and also potentially stretch some stitching. If you're marking up the ball every time you fire then the design will probably get called on.
Unread 16-01-2014, 13:49
The analog to 2012 and 2013 seems weak for a variety of reasons, including but not necessarily limited to: a) the fragility of the game piece, b) the likelihood of abuse causing total failure of the gamepiece, c) the likelihood of failure of a game piece affecting match outcome, and d) the cost of a game piece
Unread 16-01-2014, 14:16
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Exactly, damage a frisbee or foam ball that costs a few dollars VS a $52 ball, you do the math.
Unread 16-01-2014, 14:19
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
In 2008, they were quite strict about this. When they began to find small melted areas or areas that had hardened due to friction on the outer cover, the field officials went robot to robot to determine the most likely culprits and warned them that they would be DSQ'd if they continued to damage the ball.
Teams would do well to make one of their design priorities NOT damaging the ball. It's really not something you want to worrying about come game day.
Unread 16-01-2014, 21:07
mrnoble's Avatar
teacher/coach
Thanks folks, I missed that one.
We might have found a reasonable solution, so we'll see.
