Go to Post May your shirts be full of buttons, yours inspiration be plentiful, and your error messages be few. - Barry Bonzack [more]
Unread 16-01-2014, 13:59
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Thanks for the input. I was looking high and low in the pneumatics section and found nothing.
So as long as it is less than $400 and has 1/8" pipe thread, and 125psi rated its legal?
Unread 17-01-2014, 13:35
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Re: Solenoid Legality
Technically, the solenoid valves don't have to be rated for 125 psi if you use a second safety relief valve set lower than the solenoid's rated pressure. But yes, those are the only requirements this year.
