Go to Post We do a disservice as mentors if we simply complain. We must inspire our students by showing them how we rise to the challenge and solve the problems we face. - Jon236 [more]
Unread 16-01-2014, 15:24
unknownID unknownID is offline
FRC #3688
unknownID is an unknown quantity at this point
Which Eclipse program do I install.
I'm wanting to program in c++ language and Java but which programs do I use. For example what eclipse program do I install.
Unread 16-01-2014, 15:37
Re: Which Eclipse program do I install.
Instructions for getting started with C++ and LabVIEW are available from the Control System documentation.
Unread 16-01-2014, 16:37
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
As mentioned above Java and C++ instructions are available on screensteps live.
The default IDE for Java is Netbeans.
And the default for C++ is Wind River Workbench
If you are dead set on using eclipse. A member of my team put together a guide on how to do this. This was for the 2013 season, but is nearly identical to what's required for 2014.
http://www.chiefdelphi.com/forums/sh...d.php?t=110420
http://team2168.org
Unread 16-01-2014, 19:29
yash101 yash101 is offline
AKA: null
For Java, it is recommended that you use Netbeans. You must use WindRiver IDE for C++, though. However, that is still based off eclipse.
Unread 16-01-2014, 20:28
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
Actually, you don't have to use WindRiver for C++, but it's documented much better than other methods. The latest versions of GCC (4.8 and above) support building C++ code for VxWorks on PowerPC, which is what the C++11 toolchain mentioned elsewhere uses. One can use their editor of choice and deploy their code with make.
While it has proven to be very stable across multiple platforms in my opinion, newer teams should definitely go with WindRiver since it has examples and better documentation. Also, others can give them help if needed.
Unread 16-01-2014, 23:54
AKA: null
Sweet! I love the command line
