Go to Post I don't think we should only be pointing at those with exceptional bots, but those that we consider a role model team in all aspects, not just in technical design - tribotec_ca88 [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #44   Spotlight this post!
Unread 16-01-2014, 15:55
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: 95 Hard at work
This work is just beautiful. Well done.
With SolidWorks 2013 you can create dxf output from the Flat Pattern without setting up a drawing.
You can create *.dxf files of sheet metal flat patterns from sheet metal part documents without flattening the model or creating a drawing. This helps to export Dxf files to other applications, such as punch press or laser-cutter programming software.
Use one of these methods:
Click File > Save As and select Dxf (*.dxf) for Save as type.
Right-click Flat Pattern in the FeatureManager design tree and select Export to DXF/DWG.
Marie
