Go to Post This site is truly the best resource out there for FIRST teams, the information that flows on here is just amazing and I don't know what FIRST would be like without it. - Ricky Q. [more]
Go Back   Chief Delphi > Technical > CAD
Unread 16-01-2014, 16:32
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
SolidWorks Sheet Metal 2013 Tips for FRC Teams
More and more I see FRC teams using sheet metal or wondering about using sheet metal. If you have a part that is of constant thinkness, you can consider using sheet metal. I personally used sheet metal for laboratory robot design. It’s strong, light, easy to fabricate and when time is an issue – sheet metal is a great option.
So here are Marie’s tips - some may have been proposed by others but I thought I would put them together.
1. SolidWorks Sheet Metal is available to all teams. Right-click in the Command Manager in SolidWorks. Click Sheet Metal to get all the sheet metal tools.
2. Usually you design in 3D and then create the flat pattern in 2D. I like to flatten after every feature I create, just to be sure the part will flatten. I recommend if you are new to sheet metal, go through the sheet metal SolidWorks Tutorial under Help>SolidWorks Tutorials.
3. If you have a sheet metal mentor or sponsor, ask “what is your bend radius” or “what is your preset tooling” Don’t enter in a bend radius of .5 (theoretical ) or 0 (what you think you want), these don’t exist – really. Don’t use a hole diameter, that isn’t a standard for your sponsor or sheet metal house that you work with. This will save time.
4. New at SolidWorks 2013 is the ability to export the flat pattern right to DXF for manufacturing and to create multi body sheet metal parts.
5. How much will it cost and when can I have it? Try Solid Quote from Rapid Sheet Metal http://my.solidworks.com/item/015100/0550050104. Solid Quote is a free Add In that will give you an idea on how much things cost and how long it will take. The app works with SolidWorks and PTC Creo.
6. Simple Stress. Stay away from holes close to edges. Ask your sheet metal manufacture for rules of thumb based on material, thickness and your design. A little conversation up front, saves design time and mistakes.
7. Once, I went to a senior citizen center and talked to a "tin knocker" before I picked up a mouse for a new project. You can learn alot from an experienced tradesman. Marie
Unread 16-01-2014, 16:35
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
Re: SolidWorks Sheet Metal 2013 Tips for FRC Teams
I know this post is unrelated but I need help do you know if we can us color sensor?
Please Help I am so lost.
Unread 16-01-2014, 16:40
I dont understand the question
Unread 16-01-2014, 16:46
FRC #2345
my team want to know if we can us a color sensor on the robot?
Unread 16-01-2014, 16:57
I would search for "sensors" on CD an then ask in the sensors or NI forum. Someone can propabably help you there. Not my area. Marie
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Your question has nothing to do with Solidworks or sheet metal.
Post it in the appropriate forum (try http://www.chiefdelphi.com/forums/fo...play.php?f=173) and you'll get better results.
--Madison--
...down at the Ozdust!
Unread 16-01-2014, 17:06
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
I have been going through the sheet metal tutorial, and on the miter flange step, it refuses to propagate along the adjacent edge. Any tips?
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 16-01-2014, 19:54
When you select the inside edge for the Miter flange, be certain to pick the edge towards the top left vertex. You want a plane, Plane 1, to be created ll with Top plane, but through to top most point. My guess is your plane is in the middle, towards the bottom inside face. The "propogation" for a Mitre flange only goes in one direction - not both. Marie
