Go to Post Darn, I won't be at Pittsburgh. But I ain't going anywhere this year without my gracious professionalism! - Eugenia Gabrielov [more]
Unread 16-01-2014, 18:21
Nathan Powell's Avatar
Nathan Powell Nathan Powell is offline
The Prime Function
FRC #2582 (PantherBots)
Nathan Powell is an unknown quantity at this point
Programming Help: E4P Encoder
Greetings.
This year my team has decided to use AndyMark E4P encoders on our drive train for use in autonomous. We are using the SmartDashboard as an alternative to the FRC Dashboard. However, after mounting them and and running the code, we encountered some difficulties:
  • The encoder rate begins counting in increments of 1 as soon as tele-op is enabled. Disabling stops it, but it begins again when enabled
  • Whenever the encoders are plugged in, our drive chain does not work. Either it doesn't respond to the joystick input, or the encoders might be blocking it somehow.
We've checked the wires, and tried different variations of the code below. I've also searched Chief Delphi, but nothing I've found seems to work. Can anyone offer assistance?
#include "WPILib.h"
#include "AnalogRangeFinder.h"
//#define ANALOG_CHANNEL_FOR_SONAR 1
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
//static int ULTRASONIC_ECHO_PULSE_OUTPUT = 3;
//static int ULTRASONIC_TRIGGER_PULSE_INPUT = 4;
class RobotDemo : public SimpleRobot
	RobotDrive Tank_Drive; // robot drive system
	Joystick stick;
	Encoder en_right;
	Encoder en_left;
	Victor Arm_Motor;
	//AnalogChannel pot;
	//AnalogRangeFinder us;
	//PIDController *armPID;
	LiveWindow *lw;
	//SmartDashboard sm;
	//DigitalInput ULTRASONIC_PING;
	//DigitalOutput ULTRASONIC_ECHO;
public:
	RobotDemo(void):
		Tank_Drive(3,4,2,1),
		stick(1),
		en_right (5, 6, true),
		en_left (7, 8, true),
		//us (1, 2),
		Arm_Motor (3)
		//pot (1, 1)
		//us (ANALOG_CHANNEL_FOR_SONAR)
		//armPID->Enable();
		//pot = new AnalogChannel(1);
		//armPID = new PIDController(1, 1, 0, &pot, &Arm_Motor);
		lw = LiveWindow::GetInstance();
		//lw -> AddSensor("Arm", "Potentiometer", pot);
		en_right.SetMinRate(10);
		en_left.SetMinRate(10);
		en_right.SetDistancePerPulse(200);
		en_left.SetDistancePerPulse(200);
		//us.SetDistanceUnits(Ultrasonic::kInches);
		//us.SetAutomaticMode(TRUE);
		Tank_Drive.SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		en_right.Start();
		en_left.Start();
		Tank_Drive.SetSafetyEnabled(false);
		Tank_Drive.Drive(-0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 				//    for 2 seconds
		Tank_Drive.Drive(0.0, 0.0); 	// stop robot
		en_right.Stop();
		en_left.Stop();
		en_right.Reset();
		en_left.Reset();
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		en_right.Start();
		en_left.Start();
		Tank_Drive.SetSafetyEnabled(true);
		while (IsOperatorControl())
			//double range = us.GetRangeInches();
			//DriverStation::GetInstance();
			//DriverStation::CheckAnalogChannel(1);
			//armPID -> SetInputRange(.8, 1);
			//armPID -> SetOutputRange(.25, .5);
			//armPID -> SetSetpoint(3);
			//Tank_Drive.ArcadeDrive(stick); // drive with arcade style (use right stick)
			Tank_Drive.SetLeftRightMotorOutputs(1 * (stick.GetRawAxis(2)) + stick.GetRawAxis(1), 1 * (stick.GetRawAxis(2)) - stick.GetRawAxis(1));
			//Tank_Drive.TankDrive(stick.GetRawAxis(5), stick.GetRawAxis(2));
			//if (stick.GetTrigger()){
			//armPID -> Enable();		//Starts calculating the PID values
			//always check the cRIO card first!!
			//SmartDashboard::PutNumber("Potentiometer 1: ", pot.GetVoltage());
                        SmartDashboard::PutNumber("Encoder 1 Rate: ", en_right.GetRaw());
			SmartDashboard::PutNumber("Encoder 2 Rate: ", en_left.GetRaw());
//SmartDashboard::PutNumber("Encoder 1 Count ", en_right.Get());
			//SmartDashboard::PutNumber("Encoder 2 Count: ", en_left.Get());
			//SmartDashboard::PutNumber("Rangefinder 1: ", range);
			//SmartDashboard::PutNumber("Y-Axis", stick.GetRawAxis(2));
			//SmartDashboard::PutNumber("X-Axis", stick.GetRawAxis(1));
			//SmartDashboard::PutNumber("armPID: ", armPID -> Get());
			Wait(0.005);				// wait for a motor update time
			//armPID -> Disable();
		}en_right.Stop();
		en_left.Stop();
		en_right.Reset();
		en_left.Reset();
	 * Runs during test mode
	void Test() {
			//		DriverStation::CheckAnalogChannel(1);
START_ROBOT_CLASS(RobotDemo);
I know, my code's a little messy at the moment, but I've been working on other sensors in addition to the encoder. Sorry for the inconvenience.
Unread 16-01-2014, 18:35
Re: Programming Help: E4P Encoder
Originally Posted by Nathan Powell View Post
I meant "inconvenience". Apologies.
You can edit your post if you want.
Unread 16-01-2014, 19:41
At what rate does it increase?
Unread 17-01-2014, 17:28
The Prime Function
It's now increasing in increments of 2 about every quarter second.
Unread 17-01-2014, 17:38
The Prime Function
When I remove the parameters I set (.SetMinRate(10) and .SetDistancePerPulse(200)) it increased in increments of one about every half second. Not sure why, though.
Unread 17-01-2014, 19:40
The Prime Function
Never mind: it turns out that the electrical team did not check the PWM wires as close as they claimed, as opposed to a coding error.
-sigh-
Thanks to everyone who offered their advice.
